Old 12-01-2011, 10:39 PM   #1
warrenivan's Avatar
1981 28' Airstream 280
Santa Barbara , California
Gah! A *hole* new problem (LPG leak)
So we're living in our rv for ten days (which we are still fixing up, waiting on new chassis batts and inverter)..
My wife smelled propane outside, so we went exploring. After some sniffing, soap and flashlight fun, we discovered this hole, in what I am assuming is the LPG regulator.
My question is.. Why is propane flying out of it? The hole looks like it was meant to be there.. so is it a matter of tweaking some knobs? or is the regulator pooped?
Thoughts?
Here's a picture of the culprit:
warrenivan is offline   Reply With Quote
Old 12-01-2011, 11:43 PM   #2
1974 Argosy 20
Kooskia , Idaho
It is a vent hole, usually to allow atmospheric pressure to the back side of the rubber regulator part inside. If it is leaking out of there, time to replace the regulator.
They are not expensive, only around 30 to 40 bucks, and seldom last more than 20 years safely. Just more maintenance on the older rigs we have.
Old 12-02-2011, 12:25 AM   #3
warrenivan's Avatar
Thanks idroba.
Will replace it ASAP.
Old 12-02-2011, 10:16 AM   #4
1989 34.5' Airstream 345
Silverton , Colorado
Turn off the tank, bleed the pressure out of the lines...
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 12-02-2011, 11:20 AM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
There is a little rubber diaphram in the regulator which is the sensing element to set your pressure at 11 inches of water. The rubber deteriorates over time and can develop a hole. The regulators are not field serviceable and you need to replace the whole thing. Buy one with an automatic switch over feature, so you do not have to get up in the middle of the night to change the valves to use the other tank.
Old 12-02-2011, 07:33 PM   #6
crazeevw's Avatar
Saint Petersburg , Florida
dwightdi, with 'us' motorhome owners, we don't have multiple tanks to require the need for a switchover feature. My 345 has a 125lb tank.
Thanks, Derek
Old 12-02-2011, 09:16 PM   #7
1977 31' Sovereign
1989 34' Excella
I overlooked your little picture. Have fun in your new life style.
lpg, propane, regulator, tank
Potential Problem? Pictures included palmtreegirl 1990 - 1993 Excella 51 08-12-2013 10:50 PM
Oh where, oh where is that leak coming from? idmtman Fresh Water Systems 0 11-28-2011 11:01 PM
Where Is My Leak? Chaplain Kent General Repair Forum 6 10-07-2011 11:55 AM
Frustration !!Water leak at front of trailer!! william Haym Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-06-2011 11:41 AM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
