Old 08-05-2015, 04:39 PM   #1
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
FYI Classic motorhome Isuzu accelerator cable or throttle cables.
I think I posted somewhere that due to a fan belt disintegrating, (another thread, another time) it drove my throttle or accelerator cable into the fan. I scoured the air forums finding this thread
http://www.airforums.com/forums/f311...sel-51952.html
which gave me this part number...
Chevrolet GM Workhorse Throttle Cable #1248092 69" 262/292/350/454 & 4BT
The posting also stated that an Airstream tech who used to work at the factory doing the conversions stated the same cable was also used on the Isuzu diesels; so I purchased the cable the same day my broke. Later on when the weekend came I had a chance to remove my cable, (that unfortunately had no part number on it), to compare with the picture of the cable on order. The cables matched for the most part but had a different length and what looks like a different end at the pedal side. I haven't got the cable yet but I am certain the pedal attachment is different.
I have since found another cable that matches percisely the cable I removed from my Isuzu diesel.
https://www.millsupply.com/66-accele...13.php?p=47087
If your accelerator cable at the pedal just snaps off, this is the cable you want.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 08-05-2015, 04:49 PM   #2
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Great info to have Tony, thanks for posting. Its generally a matter of when not if.
mayco is offline   Reply With Quote
1981 454 P30 throttle Body cable ASTailgate Mechanics Corner - Engines, Transmission & More... 1 07-02-2014 08:43 PM
Throttle cable TAE Argosy Motorhomes 4 06-24-2012 02:03 PM
accelerator cable for 1982 Isuzu diesel mcplaidpiper Classic Motorhomes 7 06-08-2009 09:05 AM
Argosy throttle cable mcneon Mechanics Corner - Engines, Transmission & More... 7 08-24-2003 09:17 PM
accelerator cable islandvu3@cox.net Airstream Motorhome Forums 1 05-26-2002 11:02 PM
