Old 09-23-2007, 09:28 PM   #1
philippes's Avatar
1994 36' Classic 36
Cincinnati , Ohio
Fuse Block
Who knows who is the manufacturer of the chassis fuse block on a 1994 MoHo? I have a gas P30 Chevrolet chassis. GM and Airstream are all throwing the ball at each others. The last that I heard is that the part would have been supplied by GM on a separate box. P/N would be appreciated.
Philip
philippes is offline   Reply With Quote
Old 09-24-2007, 03:29 PM   #2
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
Do you mean the 12vDC fuse block in/under the dashboard that controls the chassis wiring such as headlights, instrument lights, horn, etc.? If so, that was definitely a GM part because it was on the drive-away chassis when it was delivered to Airstream.
If you find the actual part number please post it ... there are many of us that need to know.
jking is offline   Reply With Quote
Old 09-24-2007, 05:10 PM   #3
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Regardless of the part# it is probably not adequate for your coach today. Granted MH is a few years older than yours but it only had six factory fuses. Over the years so many additional items were added to these circuits it looked like a bowl of spaghetti under the dash. You can purchase an after market fuse block with adequate circuits for a modern coach and either mount it along side your existing block or replace it entirely and put it somewhere easy to access.
Good luck to you.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 09-24-2007, 08:51 PM   #4
philippes's Avatar
1994 36' Classic 36
Cincinnati , Ohio
Jamie,
Yes, it is the fuse block below the dash. It has approx 20 fuses.
Philip
Old 09-25-2007, 06:52 AM   #5
Jamie
jking's Avatar
1984 31' Limited
Philippes -
In that case I second Chaplain Kent's advice. The old fuse blocks were inadequate even when they were new! Check out your favorite automotive/truck parts place.
Jamie
Old 09-26-2007, 08:23 PM   #6
philippes's Avatar
1994 36' Classic 36
Cincinnati , Ohio
It has 20 GENUINE fuses.
Old 09-26-2007, 08:40 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Check to see what the fuses power. If it is mostly stuff for the body, it should be an Airstream part, if it controls the chassis, such as ecm, fule injectors, dash radio, running lights, it is GM.
Broken Fuse Block In Distribution Panel - How Best To Repair montanaandy Batteries, Univolts, Converters & Inverters 12 06-01-2015 08:01 PM
Fuse block driving me nuts! bkahler Mechanics Corner - Engines, Transmission & More... 11 07-08-2007 08:52 PM
New kid on the block gladhand Member Introductions 1 07-11-2006 06:30 AM
block heater apetit Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 2 01-20-2005 07:01 PM
Fuse Block replacement - help Craig Electrical - Systems, Generators, Batteries & Solar 6 10-13-2004 03:01 PM
