Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 07-25-2007, 01:13 PM   #1
pjude
Profile:  Tyler , Texas
Furnace damage
HI! Is there any type of diverter available for the exterior Suburban heater vent?
On my moho the exhaust has buckled he aluminum skin and the rubber trim has melted. As always any input is appreciated. One more question: there is a red light to the right of the ignition key. What is it for ...it comes on an goes off for no apparrent reason. I also have a rocker switch on the right side of the entry door that I cannot trace.
pjude is offline   Reply With Quote
Old 07-25-2007, 03:36 PM   #2
guy99
guy99's Avatar
Profile:  Dunsmuir , California
Images: 16
On my rig (1984 310 Limited) the red light near the key is a warning light for the levelers. Until I went through the wiring and the sensors on the levelers mine would go on and off at random.
To the right of my door (from the outside) I have the living room light switch, (hi, off, low), the porch light over the door (off, on), and the "scare" light switch (off, on).
1984 310 Limited Motorhome
guy99 is online now   Reply With Quote
Old 07-25-2007, 07:16 PM   #3
Wabbiteer
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
I think I would check the regulator to ensure it is not supplying too much gas - I believe eleven inches of water column is appropriate for propane, too high of pressure will raise the exhaust stack temperature dramatically...
Powered by Tinnitus
RE & Alt Energy Hope Chest
RE Forums
Wabbiteer is online now   Reply With Quote
72 Airstream International Furnace parts loechli Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-20-2008 07:17 PM
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 05:36 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 09:59 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 09:41 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 08:29 PM
