Old 04-03-2011, 03:22 PM   #1
st.stephan's Avatar
2012 27' FB International
1975 26' Argosy 26
Flora , Indiana
Fuel tank leak 1985 345 classic
Need solution for fuel tank leak - pretty fast! Had tank repaired in Oklahoma last summer but realize we have developed a leak. Any suggestions or anyone have a spare?
st.stephan is offline   Reply With Quote
Old 04-03-2011, 06:32 PM   #2
AirRowan's Avatar
1986 34.5' Airstream 345
Key West , Florida
If you clean the spot and empty your tank below the leak you could temp fix it with a dime and some JB Weld..... JUST TO GET HOME NOT AS A FIX. The PO on mine used potable water hose (the clear stuff with glass fibers in it) to bypass the step fuel filter. I pulled my tank today to clean it and paint it/ replace all fuel lines;-)
AirRowan is offline   Reply With Quote
Old 04-03-2011, 09:32 PM   #3
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
The fuel tank on my 325 diesel proved to be the source of the filter clogging problem that left me on the roadside twice during my maiden voyage home after purchasing it. The tank was filled with rust, and was beyond saving. I had a new one made up of aluminum to the exact size of the original. The cost was about $600 plus new sending unit. Maybe not what you're interested in, but a possibility.
streamquest is offline   Reply With Quote
Old 04-03-2011, 10:08 PM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
We acquired a 1937 Buick about 15 years ago with the same fuel tank problem. Fuel tanks for 1937 Buicks cost about as much as for old Airstream/Argosy motorhomes.
I used the POR 15 fuel tank restoration system with great success.
FUEL TANK REPAIR KIT-POR-15 Inc.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Classic vs Classic limited Flying Gypsies 2006 - 2010 Classic (all lengths) 13 10-15-2011 06:37 PM
Any ideas for a new gas tank Kandacelyn Classic Motorhomes 4 04-16-2011 07:15 AM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
2011 Ford Super Duty Diesel, Don't trust the fuel calculator hhendrix Tow Vehicles 19 01-13-2011 09:18 PM
