Old 09-14-2016, 01:01 PM   #1
1991 35' Airstream 350
Windsor , North Carolina
Fuel scrubbing?
Been working on the 350LE. Now that the fuel gage works, I find that I have almost a full tank of gas, which has been sitting for 6-7 YEARS. Why it has been parked for that long is, well, a long story. I have several questions--
Can anyone tell me the gas tank capacity? I cannot remember.
Do I dare trying to use this fuel? I do not remember if I put fuel stabilizer in it when it was parked. I have no easy way to inspect it to see if it has begun to turn to varnish.
Has anyone had any experience with having fuel scrubbed, tank cleaned, etc.? I know this is relatively common on boats, but one of the companies I called has told me that they have never done a RV--and they might have to take the tank out to get it cleaned--surely difficult with close to 500 lbs of fuel in it.
Best to all,
Rob
ralley is offline   Reply With Quote
Old 09-14-2016, 02:40 PM   #2
1979 23' Safari
Wayland , New York
You'll probably have to siphon the gas out of the tank then drop it to clean it out. 6-7 year old gas, even with fuel stabilizer=no good. Since it probably had ethanol in it it probably absorbed some water so you may have some corrosion in there too.
Old 09-15-2016, 11:12 AM   #3
1979 28' Airstream Excella 28
Albuquerque , New Mexico
I have diesel, and drained about 20 gallons from a 1/4 drive nut under the tank.
For old gasoline, I have had good luck with a fuel stabilizer and sea foam
kyote is offline   Reply With Quote
Fuel Line & Fuel Tank crazeevw Mechanics Corner - Engines, Transmission & More... 4 12-02-2011 08:38 PM
Right rear tire scrubbing Cracker Tires 24 09-15-2005 11:24 AM
cleaning with scrubbing bubbles another project General Interior Topics 4 12-21-2003 07:01 PM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 11:16 AM
Advice please - Travels, Flags, Fuel and Caravans NickSowter On The Road... 6 06-27-2002 11:04 AM
