Old 09-21-2010, 11:11 AM   #1
moeriv's Avatar
1988 34.5' Airstream 345
Livingston , Texas
Fuel pump question 1988 345
Is the fuel pump that is behind the tag axle supposed to humm when the ignition key is turned on? I am a newbie to this MH.....just fixed a leak on the air suspension that caused the air compressor to run constantly, but now that the compressor doesn't run all the time, I can hear the fuel pump. I don't know if the humm is normal or if the fuel pump is going out.
Thanks for any help. Moe
moeriv is offline   Reply With Quote
Old 09-21-2010, 11:55 AM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
All electric fuel pumps make a humming sound,usually louder when you first turn on the key,the newer units have fuel pump in tank,that keeps them a lot quieter. Dave
easyride is offline   Reply With Quote
Old 09-22-2010, 03:09 PM   #3
moeriv's Avatar
Livingston , Texas
Thanks for the info! Moe
Old 09-23-2010, 07:14 AM   #4
1989 34.5' Airstream 345
Silverton , Colorado
Our 89 hums...it's when it doesn't that I worry...last time it shut up, it got replaced...I now carry a spare...I hope the in-tank never requires replacement...m
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 09-23-2010, 04:05 PM   #5
1988 32.5' Airstream 325
calgary , alberta
Mine always hums and good advice to carry a spare! I travelled from hamilton to buffalo it would run for a mile then run out of gas!! Did not know it had a pump at tank !! the two hour trip took two days even rv shops were stumped!!
jhenry is offline   Reply With Quote
Old 09-23-2010, 10:18 PM   #6
The main problem with 34.5 feet of motorhome is that when it doesn't work, it's a BIG albatross...however, when it's running smooth, it's an eagle...wish I could predict the flight pattern...glad that isn't my main aim...we'll drive it till it dies or we do...m
Michael & Tracy
1989 345 Motorhome
Old 09-30-2010, 03:17 PM   #7
moeriv's Avatar
Livingston , Texas
OK...decided to replace the fuel pump. Any idea on part numbers for the pump. Can't find any info on replacement. Looked at a Holley Red Fuel Pump, but I am not sure what flow rate is required. Thanks for any help.
ps on a 1988 345 with 454 chevy p30
Old 10-01-2010, 02:12 PM   #8
easyride's Avatar
1977 27' Overlander
Naples , Florida
Replacement fuel pump
I think I would call someone like Jegs and ask them what they recommend ,I`m sure they know what would work good for you. Dave
Old 10-02-2010, 06:25 AM   #9
Jamestown , Kentucky
Images: 13
I have found that NAPA, has them in stock, most Stores
about $100. to $140.00 and that is with a new fuel flow controller.
I replaced mine in Florida this winter, and purchased a spare also.
For ease, I also purchased Two Brass Ball Valves and put them in Line, before and after the Pump. this way I can shut the valves OFF. and replace the Pump with Little fuel loss, draining.
IF, You have a Plugged Fuel Filter ? The Pump will HUMMMM ?
Louder I have Found.
John H. is offline   Reply With Quote
Old 10-02-2010, 07:00 AM   #10
raveson's Avatar
boca raton , Florida
On my 89 have never noticed a hum even when the filters were plugged.
raveson is offline   Reply With Quote
Old 10-02-2010, 08:54 AM   #11
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
When I purchased my motorhome I was running out of fuel on hills. The fuel pump at the tank hummed but it wasn't pumping fuel. I checked by taking off the out line at the pump. Purchased new pump, that eliminated the problem.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 10-02-2010, 11:29 AM   #12
I replaced my fuel pump with a Holley12-802-1
The other # on the box is 90127484296
Michael & Tracy
1989 345 Motorhome
1988 345 Motorhome Brochure crazeevw Classic Motorhomes 8 05-09-2010 07:54 PM
Seeking Help w/CUSTOM 1988 345 New2it General Interior Topics 12 07-28-2006 02:20 PM
Drawer slides 1988 345 howardann Airstream Motorhome Forums 10 03-15-2003 09:14 AM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
