Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 06-25-2014, 04:18 PM   #1
1981 28' Airstream 280
Fuel pump location 81' Excella 34'
Would I find the fuel pump in or near gas tank or would it be mounted on engine?
VMan is offline   Reply With Quote
Old 06-25-2014, 06:15 PM   #2
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Assuming you have a 454 motor, you probably have a mechanical fuel pump toward the bottom of the motor at the right front side. A lot of us also have electric pumps to help get the fuel to the mechanical pump, usually mounted in-line near the tank.
Waipio Rim is offline   Reply With Quote
Old 06-26-2014, 11:33 AM   #3
Thanks for the detail. I figured there might be 2. I did locate the mechanical pump. Unfortunately, 1 of the 2 bolts played hard to get out. Now that bolts head is rounded off. I tried everything I had to no avail. Impact wrench, lubricant to soften the rust bond, ratchet with a long arm for more torque, tapping on head to hopefully loosen, tightening back down on opposite bolt to take some of the strain off, nothing worked, now I'm planning to drill it out. I didn't use a torch for good reasons.
Seems like every bolt takes a half a day, in the Texas heat! Must be the heat.
Thanks again for your help. Any suggestions.
fuel pump location? jagcb750 Classic Motorhomes 17 12-17-2010 12:57 PM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
Fuel pump relay location 1993 Classic custom Scrapile Classic Motorhomes 3 08-08-2006 08:42 PM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
