Old 10-02-2011, 06:08 PM   #43
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
I've had luck with fiberglass cloth and PVC cement. Clean the surface, gob with PVC cement then lay the cloth in it. Keep adding cement and more cloth ever time it drys until you're happy (or stoned).
In two weeks I go on a short 230 mile round trip. I got 316 miles on this tank now, so I need to buy 6 gallon of gas to get home on fumes. I have put 76 gallon in, but it was cutting out the last 4-5 miles to the gas station. Better plan on 10-16 gallon to be sure. I can't push it or can I turn/stop it without the engine running.
choctawmel is offline   Reply With Quote
Old 10-03-2011, 11:51 PM   #44
I make a slurry of MEK and ABS bits... works great.
Further to the filler pipe saga... I was woking on the Utilities compartment, pulled the sewer pipe storage out, and there it was...
Looking rearward...
Old 10-04-2011, 12:50 AM   #45
1965 22' Safari
East Islip , New York
Going to chime in a bit on this one, as I'm seeing a few things that I'm not comfortable with in the photos and discussion related to fuel lines.
One is that I'm not seeing mention of pressure ratings, and it's a big problem popping up these days. If you're running any kind of in-tank or electric pump, you really want to make sure the line is rated for the pressure. Old mechanical fuel pumps running into carburetors ran pressure in the single digits, and even then was mostly hard-line from the pump to the carb. Modern EFI pumps in-tank are generally running 30-35psi, with some oddball setups much higher than that. IIRC the old GM TBI systems are around 15psi or so.
People are talking about ethanol compatability, which is good to see, E85 will destroy your fuel lines in a hurry if you accidentally put it into a non-compliant vehicle.
I have to say too that I am NOT a fan of those stainless worm clamps, particularly in a high pressure area. Over time it causes the fuel line to work harden and shrink, as the rubber expands/contracts, causing leaks about two or three years down the road. They may be a pain in the ass, but those squeeze style factory clamps really are better in the long run (but still get new clamps). And, again, if it's a high pressure EFI setup, you really need to get proper EFI clamps or you will eventually have lines blowing off the barbed fittings. Oedicker "ear" style crimp clamps are also very good for that type of installation.
-Hans
HHaase is offline   Reply With Quote
Old 10-04-2011, 11:41 AM   #46
Very good points Hans, and thanks for the info on the clamps!
Can you be more specific on whattype of clamp is best?
I spent a little time crawling about, and looking at the Grey tank hard pipe.... its not gonna be fun, but I have to do it...
I noticed something else yesterday.....
On the Chassis hard pipe, above the axle... the worm clamps on the junction to the rubber pipes, are pointing UP!
That can only mean that the last time the were tightened... it was done from above... meaning when it was a bare Chassis!
Original, 27 year old rubber piping... not a good thought!
Old 10-04-2011, 11:47 AM   #47
1965 22' Safari
On the Chassis hard pipe, above the axle... the worm clamps on the junction to the rubber pipes... are pointing UP.. That can only mean that the last time the were tightened... it was done from above... meaning when it was a bare Chassis... meaning its original, 27 year old rubber piping... not a good thought!
Lots of good options out there. When I did the EFI conversion in my CJ-7 I used "double ear" clamps, but you do need a special tool to install them and removal isn't easy.
double ear clamp,double ear clip manufacturer and double ear clamp,double ear clip supplier--China Ningbo Kingsun Hose Clamp Factory.
A quick google search for "Fuel Injection Hose Clamps" turns up a lot of options. Here's what a common type looks like
Amazon.com: 10 pack Breeze FI5PB Mini G Fuel Injection Hose Clamp Effective Diameter Range: 7/16" - 39/64" (12.5mm - 15.5mm) for 5/16" Hose: Home Improvement
The important thing is that it isn't totally rigid, and has some type of spring action to it, that way it swells and contracts with the hose and gives a constant pressure. This prevents it from work hardening the rubber over time. Most people see it happen on radiator hoses more than fuel line, when they use the worm drive clamps, but the effect is the same.
-Hans
Old 10-05-2011, 03:48 PM   #48
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
Keyair, Glad my fill/vent is all under floor. Replace them in a RV park in Texas years ago. Found gas rated fill hose at the NAPA down the street.
On fuel line pressure: If at all possible I'm using SAE 30R9 hose. I just notice the 1/2 I replaced is SAE 30R6. The min burst pressure is still 175 PSI (SAE 30R9 is 500PSI) and that line is regulated at 8 PSI up to the EFI pump which is 18PSI then the R9 to the throttle body. The last hose was still keeping the gas in after 25 year. In another 25 years I'm sure either the cops or my kid will take my keys away.
Old 10-07-2011, 08:24 PM   #49
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Wondering, with the fuel lines in our Classic motorhomes really not designed for 10% ethanol blend gasoline, any thoughts as to maybe that's some of the problems with our generators? Maybe I need to get the filters all switched out and see if I can get it started. I did put some "Sea Foam" additive in my fuel tank to see if it wouldn't help with some of the ethanol problems. Was going to use StaBil, but Sea Foam was recommended. Any thoughts?
Thanks, Derek
Old 10-08-2011, 09:21 PM   #50
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Derek I used seafoam but in a different way, I opened the line just below the filter, took off the filter and was able to put it in the line, reattached the filter, after 3 tries and a day of sitting it started. I took the carb bowl off and cleaned out crud, sqirted carb cleaner in all opening. When I read the directions of seafoam, you would have to use a gallon of it for a tankful of fuel.
Old 10-08-2011, 11:43 PM   #51
I love Seafoam...
I have heard people call it snake oil, but I recently cured a misfiring Nissan with it... Injector was, I assume part blocked... a 1/4 tank of fuel and a whole quart of Seafoam, and it was cured... and 2k miles later still running great.
I suggest, as the the genset has its own fuel pump, putting a gallon of gas, in a can with maybe half the can of Seafoam... detach the fuel feel line and feed it from the can... Run the whole gallon thru, and it should help.
Old 10-09-2011, 06:01 PM   #52
1987 34.5' Airstream 345
Milton , Florida
My Gen Set problem was much more simple, so far. Rodents made a nice home on top of the gas tank and chewd thru the gen fuel supply line. Thankfully, not the main supply line to the carb. Sooo dropping the tank and replacing as much rubber as I can get to, with the type suggested here, as well as the filters.
Is there anything I can put on the lines, besides a cat, that will make it distasteful to mice. Seems like a business opportunity...
navyspook is offline   Reply With Quote
Old 10-09-2011, 08:29 PM   #53
crazeevw's Avatar
No idea about a cat on top of your fuel tank, but my Mom throws out red pepper on her landscaping to get rid of cats.......
Honestly, before you re-install the fuel tank, maybe find some of the pepper spray that letter carriers use. I know that it's only mineral oil and cayenne pepper. No idea what mineral oil will do to rubber fuel lines though. Just don't get any of it on yourself, take it from me, that stuff burns a day later, after washing myself with Go-Jo, it just doesn't go away that easily.....
Derek
Old 10-09-2011, 08:33 PM   #54
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Snakes work even better than cats.
They even keep other things besides mice away.
Vaughan
Old 10-10-2011, 07:15 AM   #55
Milton , Florida
Bingo, the pepper spray might work, not sprayed on the hoses, but on the tank to keep their feet off. I know what you mean about removing it...accidently set my wife's spray off in her purse...not pretty. The mouse was probably the same vermin that ate my Chevy pick-up's air filter.
I like the snake idea also, but you're right...it would also keep my wife away. Ya got snakes, ya ain't mice.
Old 10-10-2011, 12:40 PM   #56
When its all said and done, just the plain simple snap style mousetrap works...
$2 a piece for the larger one. Cheap enough to throw the whole thing away if ya dont want to spring the carcass.
Bait it with Peanut Butter unset for a few days, then set it...
Got the 2lb Rat that was eating our Tomatoes last week... SNAP... Dead, quick, simple and gone...
Inspecting fuel pump and tank interior DaveFL Land Yacht/Legacy Motorhomes 2 08-19-2011 06:13 PM
Auxilary Fuel (gasoline) Tank? DGJackson 1970-79 Tradewind 3 08-18-2011 10:44 PM
Extra fuel tank line? pdallas Classic Motorhomes 4 05-12-2011 09:32 AM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
2011 Ford Super Duty Diesel, Don't trust the fuel calculator hhendrix Tow Vehicles 19 01-13-2011 09:18 PM
