Old 07-19-2010, 12:58 PM   #1
Westmont , Illinois
fuel gauge sending unit
I have an Airstream Classic motorhome model 345 and I am trying to find a fuel gauge sender. Airstream says it is discontinued and so does GM. Any ideas?
hgarage is offline   Reply With Quote
Old 07-19-2010, 07:25 PM   #2
richinny's Avatar
2011 34' Classic
this thread should start you off:
http://www.airforums.com/forums/f160...ons-14068.html
i seem to remember that someone had to 'blend' two units to make one. one other post mentioned testing the sender first to make sure the sender was the problem.
Ricky
Old 07-28-2010, 10:42 PM   #3
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
I recently had a new aluminum fuel tank made up for my rig to replace the rusting original. The sending unit was as bad as the tank and also needed replacement. After contacting Airstream, I was told to pick one up at NAPA, which is where THEY go when they need one. You'll have to specify the correct ohm range so it will be compatible with the fuel gauge on the dash. As I recall, it only cost $20-30. Good luck.
streamquest is online now   Reply With Quote
Old 07-30-2010, 07:30 AM   #4
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
The easy way is to use the reset button on the odometer and get fuel when you reach 300 miles. We have been doing that for years.
Good luck with it.
Jamie
jking is offline   Reply With Quote
Old 08-01-2010, 09:34 PM   #5
Louisville , Kentucky
I got a sending unit from centriod products in Florida. They can build anything and even include a low level indicator to boot. The price was very reasonable but removing the tank was very difficult to say the least.
oliver00 is offline   Reply With Quote
Propane tank gauge sending unit rtaylor537 LP Gas, Piping, Tanks & Regulators 10 02-16-2010 04:04 PM
Temperature Sending Unit Gened Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 2 04-22-2007 06:38 PM
Propane tank sending unit gunworks Land Yacht/Legacy Motorhomes 0 10-04-2006 05:11 PM
oil sending unit for 85 MoHo? str8strm Classic Motorhomes 6 09-22-2006 07:55 PM
Gas tank sending unit questions Mr.Motorhome General Motorhome Topics 4 10-06-2004 10:57 AM
