Old 06-15-2015, 07:16 PM   #1
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Front end alignment
Anyone have the specs for the P30 front end alignment that works the best. I have used the search but can't seem to find anything.
Or is there a custom setting that works better than factory GM settings. My coach has started pulling to the right
shepherd57 is offline   Reply With Quote
Old 06-15-2015, 08:21 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
If you PM me your email I have a 32 page pdf. document that gives a pretty good explanation of the front end alignment.
Cheers, Dan
~ Margaret Thatcher ~
Old 06-21-2015, 11:00 PM   #3
bigbidule's Avatar
1981 28' Airstream 280
Lisle sur Tarn , France
Yes ! I am looking too... if it's possible : big.bidule@yahoo.fr . Thanks a lot
bigbidule is offline   Reply With Quote
Old 06-22-2015, 08:17 AM   #4
halftimer's Avatar
irving , Texas
I own a alignment shop if you didn't have a pull and have one now 9 times out of 10 it will be a tire pull . Temporary switch front tires from side to side and go drive it if your pull goes to the left or doesn't pull at all it is a tire pull a new set on the front will fix you up. Before everyone jumps in to say you shouldn't change directions of a radial tire I did say temporary. And the way the new radial tire are made you can switch directions.if you have it align a good tech can compensate for the pull and kill it then when you get new tires it wild pull because it has been adjusted to compensate for the bad tire.
halftimer is offline   Reply With Quote
Old 06-22-2015, 09:45 AM   #5
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Do you have OEM bell cranks? If you changed them out to SS, Ive got the specs. Not sure if there is a difference or not
mayco is offline   Reply With Quote
Old 06-22-2015, 12:52 PM   #6
bigbidule's Avatar
Merci beaucoup Smartstream (y) !!!
Old 06-22-2015, 06:28 PM   #7
shepherd57's Avatar
Lindsay , Ontario
Thanks for the advice on the tires I swapped the fronts on Sunday but I haven't had a chance to try it yet.
Mike
My coach has the super steer bell cranks. I checked everything on Sunday and it is all tight.
Old 06-22-2015, 06:54 PM   #8
mayco's Avatar
Do you want the alignment specs for the coach with the SS bell cranks?
Old 06-22-2015, 06:56 PM   #9
mayco's Avatar
Name:	ImageUploadedByAirstream Forums1435020976.367622.jpg
Old 06-22-2015, 07:07 PM   #10
shepherd57's Avatar
Lindsay , Ontario
Thanks Mike
I will use that when I get it done
Is this the end of my end caps? unit13 Upholstery, Blinds, Walls & Interior Finishes 9 01-02-2017 10:42 AM
Front End Alignment shepherd57 Classic Motorhomes 2 09-30-2013 05:22 PM
Ohio? Recommend a front alignment center John H. Classic Motorhomes 28 11-30-2009 06:53 PM
Hitch Ball Alignment mnikisher Hitches, Couplers & Balls 39 08-09-2005 02:29 PM
front end alignment wb13798 Mechanics Corner - Engines, Transmission & More... 2 12-11-2003 12:11 PM
