Old 01-08-2008, 08:46 PM   #1
Finally, NO leaks!
I finally managed to find the time over the last week to remove all of the old Vulkem from half of the windows on our Classic 310 motorhome. I did the windows that appeared to be the causes of the leaks we've been experiencing in the back bedroom, over the door and above the dinette table. We had a pretty good rain storm this afternoon, a real gully gusher, and when Susan and I got home we were excited to find that no water was present inside, other than a couple of drops on the table. I think those came in through the sides of the windows since all of those gaskets are in bad shape. Replacing the gaskets is going to happen down the road when I have more time on my hands.
This was my first experience using Vulkem and I really like the way it flows as you're putting it on. Definitely worth the effort .
Old 01-10-2008, 10:28 AM   #2
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
We had to replace part of the sub floor in our MH due to leaks and water damage. Might be a good idea to check yours out and try to dry out any wet flooring (I know, pretty obvious).
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 01-10-2008, 07:41 PM   #3
Sometimes its not quite so obvious so your point is well taken. As near as I've been able to tell the leaks around the windows only started in the recent past. Definitely before we got the mh but not to long before. The worst leaks were from the A/C roof units and I think those manifested themselves during our drive back from Savannah GA to Arkansas. I believe they dried out while sitting for several years and then a cold February drive on rough roads did them in. I could find no real signs of prior damage from the A/C leaks. The rear windows were due to dried Vulkem along the tops of the windows. Again they didn't seem to leak long enough to damage anything.
However once we start pulling the carpet up and installing the wood flooring I'll know for sure about any hidden damage .
Old 01-10-2008, 07:45 PM   #4
soldiermedic's Avatar
Florissant , USA
Brad....just have that energetic wife do all the flooring removal...she has the energy.
Good job BTW.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 01-10-2008, 07:54 PM   #5
Good job BTW.
Steve
Susan and I have an understanding. I do the rebuilding, repairing, fixing, etc and she does the polishing, waxing, cleaning, etc. So I'm the one that will be taking out the carpets and installing the new wood flooring. However, Susan is going to have to keep it clean, and with me around THAT is a tough job
We've also learned to divide our various other duties. I do the whining, whimpering and puling and she gets to b*tch, moan, gripe & complain. I'm not sure why she gets to do one more thing than I do but I guess thats life .
Thanks!
Old 01-10-2008, 08:04 PM   #6
Florissant , USA
Brad,
You are lucky you see it as she "Gets" to do one more thing. She may look at it that she "has" an extra chore.
Won't be hard to keep clean if you are in Pasadena ehh?
Steve
Old 01-10-2008, 08:45 PM   #7
Brad,
Ah, but Susan LOVES to work.......
Steve
Unfortunately thats true. On the bright side though its not forever and in the long run things will be a lot better for both of us.
Old 01-11-2008, 03:15 AM   #8
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Thanks!
I nominate this as the "Post of the Month".
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 01-11-2008, 07:14 AM   #9
WOW! I've never been nominated for anything before .
Thanks!!!
Old 01-14-2008, 07:44 PM   #10
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
Just riped all the carpet out of my 'Silver Bullet'.
I was one piece short of finishing installing the 'trafficMaster' allure (oak) plank floor. Just bought a new box to finish up. I put mine in east-west. If I hadn't miscut twice I would of had one plank left over. Now I'll have 15 spares planks. I'm going to caulk around the edges. Didn't find any bad sub-floor. Was going to coat the sub-floor first, but decided that chipboard had lasted 22 years, so if was good.
Couldn't believe the number of finishing nails the PO had driven through the carpet. Most of had some squicks.
Could not find a seam in the sub-floor either. Looked like it was one piece from front to back.
Now I'm working on a now cabinet for the TV. The two seats and the old TV cabinet are history.
I'd post a picture, but, can't figure that fucture out.
mel
choctawmel is offline   Reply With Quote
Old 01-22-2008, 02:56 PM   #11
Chuckles's Avatar
Iwerne Minster , Dorset. UK
OK Here goes (an Englishman asking a dumb question! ) What is Vulkem?
It sounds as if it is very liquid. I have started to seal, by the process of elimination, leaks in the bedroom. To do this I have dug out old sealer around the window frames, then using a very small wire brush clean the gap, and then reseal with clear silicone. (messy!)
Trouble is I know the silicone will eventually lift after a period of time.
it sounds as if the Vulkem will run easier into small gaps - is that so? and where would I get this (sent to the UK; - naturally)
Chuck
Dorset UK
Don't take life so seriously.... it is not permanent!
Chuckles is offline   Reply With Quote
Old 01-22-2008, 03:52 PM   #12
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Chuck, the Vulkem is more of a caulk. I'm not sure of its consistency but I'm not sure if it truly flows. I bought a product from my local Airstream dealer called Parbond which is in a small tube with a screw on cap. This stuff flows and I've used it on some questionable seams on my trailer. Nothing leaking but it flows in and solidifies after drying.
The Hot Deal - Parbond Aluminum
Jack
Jack Canavera
STL Mo.
AIR #56
Old 01-22-2008, 03:57 PM   #13
Florissant , USA
You can also order Acryl-R from the Airstream Factory. It is very viscous and wicks into the seams of the trailers quite nicely.
Steve
Old 01-22-2008, 04:23 PM   #14
As Steve mentioned Vulkem is a form of caulk, actually according to the tube I have its a construction sealant. I got it from Andy's RV. Quite pleased with its performance.
I'd strongly recommend getting a half dozen tubes from Andy and as soon as you can peel the silicone off and reseal with the vulkem. You'll be glad you did.
Do some searching on vulkem and you'll find the best ways to work with it.
Leaks mrmossyone All Argosy Trailers 2 12-04-2007 06:18 AM
Leaks, and leaks again danesh Leaks - Weatherstrips, Gaskets, Caulks & Sealants 16 09-08-2007 08:32 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
leaks maria 1959-69 Tradewind 5 11-09-2005 07:27 AM
leaks Larry Leonard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 11-03-2003 03:09 PM
