Old 01-22-2008, 04:43 PM   #15
codybear's Avatar
1964 22' Safari
SACRAMENTO , California
Images: 315
update on our safari leaks:
I ordered from Vintage 4 tubes of the 636 TremPro..worked like a dream..NO LEAKS!!!..and we did find the source of leak: the Camping World guy had left his 'knee imprints' on the panel near the ribs when he installed the a/c..
codybear is offline   Reply With Quote
Old 01-22-2008, 05:41 PM   #16
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I once thought I had all Bertha's leaks stopped, but i soon recovered from that delusion...
Old 01-22-2008, 09:28 PM   #17
soldiermedic's Avatar
Florissant , USA
Brad...it was Jack who said it was like caulk and not me. I know you think I have all the answers, but I am not the go to guy on such things
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 01-22-2008, 11:19 PM   #18
codybear's Avatar
1964 22' Safari
Images: 315
One can only dream?
Well, Terry, tell you what- I've got my fingers and toes crossed and have a couple of tarps permanently on hand in the safari, just in case!!
Old 01-23-2008, 05:47 AM   #19
Well Preserved
1993 21' Sovereign
We had severe storms here last night, and I woke up to Lake Bertha in the kitchen...
Old 02-09-2008, 07:38 PM   #20
rmpray's Avatar
1973 31' Sovereign
Bertram , Texas
Images: 21
Terry,
Assuming you have bailed out by now, have you had any luck with the leaks? I just finished seperating all my windows to remove the ancient film and are reinstalling, but all need reseal and gaskets. Did find that leks drastically decrease whe the bloody things are open one notch. That is due to water getting in through glass. With windows open it drips outside. I had used a GE ALuminum product on the shell and so far so good, but reckon I will get some Vulcrum for future use. Just was curious if you solved your water problem.
rob
Catmando
"There’s not much in life we can’t over-analyze”
rmpray is offline   Reply With Quote
Old 02-09-2008, 09:08 PM   #21
Well Preserved
1993 21' Sovereign
So far, I've resealed the hole around the center fantastic vent, and had no more leak there--yet. Another puzzler is where the cloth wall cover by my bed gets wet when it rains. No fun waking up to a wet bed, I thought I got over that a few decades ago... But it doesn't leak every time it rains, it must be when it rains from a cetain angle, or a certain amount, or both.
Old 02-09-2008, 09:26 PM   #22
Terry.
Check the sewer vent pipe gaskets.
Also check the rivets in the awning rail.
Old 02-10-2008, 07:26 AM   #23
Well Preserved
1993 21' Sovereign
Terry.
Will do, thanks.
Old 02-10-2008, 08:00 AM   #24
rmpray's Avatar
1973 31' Sovereign
Bertram , Texas
Images: 21
Where is the bed? I have the center twins and had water coming in around the AC when it was first installed. Tightened and that is cleared no.
Hope ya find it!
rob n terry
Catmando
Old 02-10-2008, 10:07 AM   #25
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
I had some leaks in my 1978 Ambassador. I took a utility knife and VERY CAREFULLY cut and scraped clean every single seam including battery boxes, windows, awning rails, lights, etc. I cleaned each seam with acetone on a rag. I used Parbond in an oilcan (with a pump trigger) type applicator and carefully laid a bead along everything I had scraped and cleaned. It wicked in and has sealed that trailer tight as a drum. It took about 2 days, with plenty of coffee breaks, to do it. Best thing I ever did.
Tom
#8848
tlavergne is offline   Reply With Quote
Leaks mrmossyone All Argosy Trailers 2 12-04-2007 06:18 AM
Leaks, and leaks again danesh Leaks - Weatherstrips, Gaskets, Caulks & Sealants 16 09-08-2007 08:32 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
leaks maria 1959-69 Tradewind 5 11-09-2005 07:27 AM
leaks Larry Leonard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 11-03-2003 03:09 PM
