These ads have been popping up accompanied by pictures of pallet loads of the specified batteries. The sealed batteries show what appear to be new NorthStar & PowerSafe brand labels. They also show(& say) reconditioned golf cart batteries.
Brand new 1,000 amp 100ah group 24 marine deep cycle batteries $69
1,600 amp 190ah 12 volt sealed AGM batteries, perfect for solar off grid car audio or any power need $125
We have some excellent 1,300 amp 100ah 12 volt sealed AGM batteries. These are all fully charged, loaded and tested. These are ideal for off grid, solar panel set up, car audio, trolling, or any power need you have. This model has a 12+ year life span if well maintained. $85
Nuway Battery will be in Charlotte North Carolina May 18-19 at the Open Air Market. We will have every battery you need from AGM deep cycle for RV or solar off grid, 6 volt and 8 volt golf cart batteries, AGM for car audio, batteries for 18 wheelers, and all make and model vehicles.
Prices seem to good to be true (none have been more than $125), but since I have multiple needs for house batteries (2 RVs) & want to add solar panels as well, I can't not go check out what they have.
Any suggestions as to caveats, checks, etc? I believe I can borrow a handheld battery tester which can confirm the numbers.
As an uninformed, under-educated semi-literate, what batteries should I be putting in the battery box for storage/house batteries? 6 or
12V, deep cycle, CC amps, ah, ?? I'm not even sure what questions I need to be asking.
