Old 06-25-2008, 03:37 PM   #1
1986 34.5' Airstream 345
Tyler , Texas
Fan/alternator belts
Hi! Can anyone give me the proper belt #s for both the alternater and AC compressor belts on a 86 345 Classic. Every parts store catalog states that the belt size listed is "except motorhome. Any help would be greatly appreciated.
Pete
pjude is offline   Reply With Quote
Old 06-25-2008, 03:48 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If no one comes back with a Number and you still have the old one any Good Industrial Supply House can measure it and set you up.
2004 Excursion 4x4
Old 06-25-2008, 05:15 PM   #3
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Generally when looking for parts for the 454 have them look up a 454 P-30 Van***
These #'s may help have them check to see if they agree with a 1986 P-30 Van
Belts for a 1990 >> 454 Part numbers
Here are the belts
Oil Filter Wix 51794
AC Belt GM 14033869, NAPA 25-7603, .380x60
P/S Belt GM10223912unr, NAPA 25-7400,.380x41
Alt Belt GM 14082454x2, Gates KO60525 21mmx1355 6PK1340
U Radiator Gates 21706
L Radiator Gates 21717
Garry
Old 06-25-2008, 06:32 PM   #4
Classic 325 MH
Eddy's Avatar
1985 32.5' Airstream 325
Rochester , New Hampshire
We have a late 85, with the 454. The belts currently used are-
Air conditioner -Gates 7585
Alternator and smog pump - Gates 7495
Alternator w/o smog pump - Gates 7455 (Ours was removed)
Hope this helps
Jeff
Jeff & Kristine
Classic 1985 325 Motor Home
New England Unit
WBCCI # 5971
Eddy is offline   Reply With Quote
Old 06-28-2008, 01:06 PM   #5
345bill's Avatar
Las Vegas , Nevada
Pete, On our 89/90 345, P30-454, installation order:
1st. NAPA, XL # 25 7410 goes on: CC,PS
2cd. NAPA, XL # 25 7590: A/C,WP,CC,PS
3rd. NAPA, XL # 25 7450: TOP AIR PUMP,PS
4th. NAPA, MICRO-V # 25 060560: ALT,WP,CC,LOWER SMOG
*without lower smog pump use MICRO-V # 25 060523
345bill is offline   Reply With Quote
Fan-tastic Fan Installation With Photos Dabler Roof Vents, Skylights & Fans 9 09-09-2007 08:18 PM
Adding seat belts and dinette bed Ellwallhome General Motorhome Topics 2 07-27-2004 08:57 AM
Dayco Belts AccessMaster Airstream Motorhome Forums 5 10-01-2003 05:51 AM
belts roskoe Mechanics Corner - Engines, Transmission & More... 1 08-16-2003 09:50 AM
1988 -345 Tires and Seat Belts MacInDaBox Airstream Motorhome Forums 15 12-12-2002 09:14 AM
