Old 08-02-2010, 06:25 PM   #1
1990 34.5' Airstream 345
Lewiston , Maine
Exterior paint
I've been working on polishing the exterior. I won't go into details about what I'm using except to say it makes a visible difference for now. Obviously at some point the clearcoat has to come off and then a decision made. At 35 feet, I don't think a mirror shine is a real option for the long run.
Anyway, the WORST feature of the unit at the moment is the deteriorating gray paint around the bottom. I think if that were taken care of, the rest, polished up for the moment, would look OK.
My question: (since I'm not able to do this myself), where do I go to get it removed and repainted, and about how much would that cost? I'm in the wilderness right now and trying to make plans for getting in and out of civilization as quickly as possible, so booking dates for the stuff. There are also cracks in the rear... fiberglass I guess?
I'm dealing with the sticky ceiling syndrome and that is almost done... well, until I looked inside a cabinet and realized the walls were sticky there too. I'm getting real sunburned on polishing. PO had removed vinyl stripe, so that is mirror finish now and that helps.
Ramblin....
gowiththeflo is offline   Reply With Quote
Old 08-04-2010, 10:11 AM   #2
Ramblin....
Ramblin,
What are you doing to get rid of the sticky feeling? Our motorhome has the same issue.
Old 08-04-2010, 06:57 PM   #3
Lewiston , Maine
Sticky ceiling
Found the solution here on the Board.
Krud Kutter. Spray on, leave for a few minutes, then rinse, rinse, rinse. You may need to do a second application.
Let it thoroughly dry though before you decide. It still feels sticky while wet.
Then you need to follow up with wax... Future wax I believe (do a search). That keeps it from coming back.
It's really great to get rid of that flypaper feel!
Old 08-06-2010, 10:26 AM   #4
Thanks for the info. Now to find someplace local that sells Krud Kutter. Interesting name!
Thanks!
Removing paint from exterior 67twinkie Cleaning, Stripping & Polishing 6 11-16-2009 12:01 PM
Exterior Paint Colors nynick52 Exterior Restoration Forum 4 09-04-2009 03:08 PM
Exterior paint dingaling Clearcoat, Exterior Paint & Trim 10 01-12-2008 11:35 AM
Exterior paint removal? SCBrat Clearcoat, Exterior Paint & Trim 9 02-06-2004 04:28 PM
Exterior paint peeling! Astrodokk Airstream Motorhome Forums 2 08-10-2003 08:18 PM
