Old 04-27-2012, 08:10 PM   #1
Bertiesue's Avatar
1982 31' Airstream 310
Portland , Oregon
Exploded hot water tank discovered
Cool pic and a good reminder of why one should winterize water system!!! I purchased this way and discovered it when I had a waterfall out the door.
ID:	156924   Click image for larger version
Bertiesue is offline   Reply With Quote
Old 04-27-2012, 09:17 PM   #2
soldiermedic's Avatar
Florissant , USA
Ouch
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 04-27-2012, 10:09 PM   #3
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
A hammer and a roll of Eternabond tape will make that look like new.
Dave
Originally Posted by soldiermedic View Post
Ouch
Old 04-27-2012, 10:56 PM   #4
1984 31' Excella
Norfolk , Virginia
Images: 11
Exploded Water Heater
If you have a good welding shop around and there is no coating/liner in that tank you can get it Tig welded for a reasonable price.
Beginner is offline   Reply With Quote
Old 04-27-2012, 11:22 PM   #5
1989 34.5' Airstream 345
Silverton , Colorado
I would opt for a replacement...your warranty will go 1-2 years, but winterization can prevent a deja-vu...duct tape will last...oh...about 30 seconds...empty the fresh water tank until it spits, turn it off, wait, turn it on again until it quits spitting, and repeat this action until the spout just pretty much spits. You can winterize with the pink stuff...I use 2-3 large bottles of the cheap vodka, and flushing the system in a decent climate is quicker...empty the fresh water tank, add vodka from the slums, run each tap till it begins to foam(don't forget the shower and toilet), and continue planning your next trip...don't let the fumes get to you!!! m
Please note that some comments to this suggestion raised questions as to the effect on the in-line water filter...we replace ours every year, so those questions, to me, are moot...pink stuff can stain, vodka leaves a hint of potato gone good for the first couple of flushes, and we frequently use bottled water for consumption purposes...in Silverton, we ARE a source of direct-line H2O: in AZ, we are in a desert-deep water source that requires filter changes...part and parcel of RVing...wouldn't change it for most anything. I ramble, so I can ramble...m
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 04-28-2012, 08:16 PM   #6
MaryContrary's Avatar
1984 31' Airstream310
on the road , CA and OR this summer!
Images: 41
when i upgrade, i'm gonna go tankless...
something like this
Girard Water Heater - Girard Products, LLC | Tankless RV Water Heater | On Demand RV Water Heaters | Endless Hot Water RV | Instant Flow RV Water Heaters | LP Gas Tankless RV Water Heater | Induced Draft Tankless Water Heater
1984 310 Limited Motorhome
my AS Moho blog
for the love of all vehicles round and shiny
MaryContrary is offline   Reply With Quote
