Old 08-23-2008, 10:20 AM   #29
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
There's a simple possibility that is often overlooked - the shift level has a lockout switch to prevent engaging the starter when not in N or P. If that switch isn't closed you get ... nothing! Next time you get nothing, try moving the shift lever . Heat can change the position of the contacts by expanding metal, so it could happen only when hot. Anyway, good luck with it.
jking is offline   Reply With Quote
Old 08-23-2008, 11:48 AM   #30
Somewhere , Indiana
Good points!
I have to agree with jking/garry! Good points guys!
NAPA parts are far better than Autozone in my experience. However GM parts have worked even better than NAPA for me.
I too, like Mustang, do a bit of dragracing and that can test some parts. It also makes makes you keep searching for a better mousetrap.
I have learned a lot from this thread. It's pretty cool to see all of the different ways that folks have solved/fixed the same problem.
Have a great weekend all,
Henry
axleman is offline   Reply With Quote
Old 08-23-2008, 01:13 PM   #31
87MH's Avatar
1978 31' Sovereign
Images: 292
Revisit a thread from early 2004
Lots of questions answered here:
http://www.airforums.com/forums/f159...noid-4748.html
and one with pictures from 2003 here:
http://www.airforums.com/forums/f159...hlight=starter
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 08-24-2008, 09:45 AM   #32
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
I wouold like to add, Start simple, and work your way in. It saves time and money in the long run. Look at the first symptoms, what you have changed, then ask youreslf if the sympotoms have changed? I keep a running notebook on my stuff, Dates changes ect. Superduty for warranty issues. Mustang for time alltitude and weather issues. other things for warranty and replacement issues. Start a time line. keep an open mind. use a volt meter or a circuit light. Never forget safety while doing all this
mustang is offline   Reply With Quote
Rust starts quickly brijbldr Repairing/Replacing Floor &/or Frame 18 08-26-2010 05:51 PM
generator starts for second and dies cutbrain Generators & Solar Power 9 08-21-2008 12:22 PM
Mini starter for General Motors 454 engine alexzero13 General Motorhome Topics 2 08-23-2007 08:16 AM
furnace starts and stops BINDER Furnaces, Heaters, Fireplaces & Air Conditioning 27 02-07-2007 10:44 AM
sheared rivet dhe9 Ribs, Skins & Rivets 8 10-03-2003 08:16 AM
