02-27-2014, 07:10 PM
1989 34.5' Airstream 345
Ebro
, Fla Panhandle
Engine fan clutch ??s
All of a sudden the engine fan is roaring away in there way too much of the time,
Seemingly unrelated to engine temp. It will free up and quite down over 50mph, but at any lower speed its roaring.
This clutch is less than one year old and was working fine till a month ago.
I checked it to day with the engine cold and not running and there is quite a bit of resistance when trying to turn it by hand maybe four or five pounds of pressure. Clearly not freewheeling.
Is it supposed to be freewheeling when cold?
Is there some maintiance that I've been missing?
Is this a sign of a failing clutch? After less than a year?
Is the switch of a thurmo/mechanical nature and internal ?
Thanks for any details you can share.
Richard
02-27-2014, 11:26 PM
Saint Petersburg
Hi Richard,
PM Dadstoy about your fan clutch. Seems Dean has had the most 'experience' with this situation.
Good Luck, Derek
02-28-2014, 07:00 AM
Princeton
, New Jersey
If the fan is running at lower road speeds I would ask when was the last time you had the radiator rodded and cleaned?
The fan is temperature activated and for some reason the engine cabin temperature sounds like it is just too high until the road speed can forces enough air through to cool thing down.
2004 Excursion 4x4
02-28-2014, 10:13 AM
1991 30' Airstream 30
San Francisco
I had the exact same problem. I replaced the fan clutch myself, and it fixed the problem- I could see that it was leaking fluid. There should be resistance when cold. If your running at normal temps on your motor this is probably the issue.
02-28-2014, 06:07 PM
Ebro
, Fla Panhandle
Thanks for the replys, I've been pretty sure that the clutch needs replacing.
I drove down to Pheonix today (about 2.5 hrs ). And it is still acting up. The air temps today were cool and the gauge never reach 210, generally under 205 indicated and the fan came on whenever the speeds dropped below 50mph, sometimes it was roaring at over 60.
Is there a brand to look for? Like I mentioned earlier, this one is less than a year old. And there is the rub for me. I don't mind replacing old parts and renewing the coach's systems. But am not too stoked replacing newer parts that were not up to the job.
I guess I'll bite the bullit and put in a new one.
Cheers Richard
02-28-2014, 06:13 PM
Princeton
, New Jersey
Your running temperature causes me to repeat my question. When was the radiator last cleaned?
If you have a 190 degree thermostat in the truck why are you running 205 plus and having the clutch fan cut in?
2004 Excursion 4x4
02-28-2014, 08:31 PM
Ebro
, Fla Panhandle
I'm not sure about your comment, HowieE. From what I gather these 454 engines do run in the range I mentioned or higher as a matter of course.
And the fan will now engage whether the engine is just started or has been running for a while and is warmed up.
Since the weather is cool this time of year where I am operating I would not expect to hear the fan engaging unless climbing a long steep climb. Then I would have switched the aux. electric fan in front of the rad to aid in cooling.
But to answer your question, I have no idea when or if the rad has been cleaned. The cooling fluid is clean and I see no gunk, nor is the fan usually this active. Just a sudden change in its operation with no apparent reason.
Cheers Richard
02-28-2014, 09:18 PM
1984 31' Airstream310
Honokaa
, Hawaii
I was worried about operating at those temps until I read the manual that came with the 310 when new. I don't recall the exact numbers, but I do remember that 200-plus was normal.
02-28-2014, 09:27 PM
Saint Petersburg
Richard, Call Raveson, I'm certain he could tell you if the radiator has ever been rodded and cleaned. Funny that it's now acting up, especially considering Raveson took the 345 on a 4 month long coast-to-coast trip last year.
As far as parts are concerned, I'd try RockAuto, or NAPA parts, simply because they stand behind their parts, and the part is usually assembled in US.
Good Luck, Derek
02-28-2014, 10:18 PM
Ebro
, Fla Panhandle
I don't feel that this is an overheating issue, the opperating temps indicated have not changed thru out the time I've owned the coach. Granted this has all been since Nov. in cool times of the year. So I have not run the rig in temps that would really test the cooling system badly, and so far it has seemed up to the task.
No, the issue is the engine fan now, all of a sudden engaging much more that before, and at engine temps that were not causing the fan to kick on before.
So I guess we have kicked this around enough for now. I'll report back once the new fan clutch is installed and let it be known if that did the trick
Thanks again for the input and suggestions.
Cheers Richard
02-28-2014, 11:27 PM
_
, _
I've put three different fan clutches on my MH. First was one from Autozone. It cycle through engaging/disengaging about every 70 seconds. That was a miserable trip to Yosemite!
Second fan clutch was from Napa. It was engaged about 60% full time! Another bad experience.
Then I bought an AC Delco fan clutch from a real parts house. It works!
I went cheap with the first two and ended up paying for my mistake in the long run. The AC Delco unit is more then the first two put together, but there is nothing like driving down the highway in a very quite Airstream!
03-01-2014, 08:25 AM
Ebro
, Fla Panhandle
Thanks Dean for the A C Delco tip, exactly what I needed to learn at this point.
As far as engine running temps goes, am I mistaken in thinking that the range between 200 and 208 degrees is about normal for these BBCs in a motorhome.
What sort of temps are ya'll seeing when cruising your motorhomes?
HowieE, still trying to understand your question. My understanding is that the thermostat helps to bring up the engine temp to safe running temps quickly when cold starting ( to assure good lubrication). So the 190 degrees you mentioned is the temp at which the devise opens to allow cooling fluids to start to circulate after that temp is reached.
I would like to see normal operating temps around 185. But it not clear to me that these BBCs are capable of running that cool. Am I mistaken in this?
Ps. I really do like that mailbox you put together, very cool!
Cheers Richard
03-02-2014, 07:15 PM
Las Vegas
, Nevada
Many of our temp gauges are famous for not being accurate and that was the reason I got a infra-red gun to verify engine running temps as well as anything else you want to point it at. They don't cost much. Great for checking wheel hubs on trips.
After a not so accurate fan clutch I got from NAPA I spent the extra $$ and got one from local GM Dealer a few years back. This one works as it should but I think fewer dealers are having them on the shelf.
03-03-2014, 07:36 AM
Princeton
, New Jersey
The thermostat is there to keep the engine at a given temperature. It remains closed until water passing through a small hole in it reaches the set temperature. At that point the temperature sensitive element of the stat open and closes to maintain that set temperature. The stat can only do it's job if the radiator and fan have removed enough heat from the water leaving the engine to allow the stat to regulate the flow entering the engine.
Under normal conditions the radiator should be able to remove enough heat to allow this. As the load on the engine increases, pulling a hill, the clutch fan is designed to come on to increase the air flow over the radiator and thus remove more heat. The fact that your fan was on at an abnormal rate was why I originally questioned the condition of the radiator.
Now another point. Factory supplied GM clutch fans have an abnormally wide range to engage. 160 to 190 degrees. This range is far to wide and can cause problems. If you have one that is close to the 160 degree engage point it will come on far more often than required. That may have been the case with some of the units noted above. But in any case the clutch fan should not come on during normal driving unless you are crossing the desert in mid summer.
Another thing to consider is the size of the radiator. Manufactures design to the lower limit and often end up with an undersized radiator. This is common when people add a heavy trailer or the engine is stuffed into an under ventilated compartment.
2004 Excursion 4x4
03-24-2014, 08:46 PM
1991 35' Airstream 350
Laurel
, Maryland
I think you could use a laser temp probe to read the temp of the radiator at many points on the radiator core to determine if there are cool spots or hot spots. That could show where water is not flowing and whether the radiator needs rodded out or new core soldered in. I pulled my radiator out and had it cleaned and rodded and soldered to fix a small leak. It was a bit of a bear to remove so I replaced the water pump and all the hoses plus belts because I wouldn't want to do this again anytime soon. I seem to only get a year out of a fan clutch and I can't figure out why. I tried a four season clutch from napa and another one from autozone. This year I bought a ac/delco so we will see. I would like to pull the fan and check its balance but it looks like it won't come out unless I remove the shroud and I ain't pulling the grill again to do that.
03-26-2014, 11:42 AM
Ebro
, Fla Panhandle
Thanks for the good suggestion of using the lazer temp probe the evaluate the function of the radiator, I'll do that once I get back to Az.and the motorhome.
Very good thinking to replace all of those expendables while in there!
What were the challenges in getting the grill et all removed for access?
No immediate plans, just for future reference
03-26-2014, 12:20 PM
Ebro
, Fla Panhandle
03-26-2014, 08:25 PM
Laurel
, Maryland
The grill is only held on with 6 bolts each side. 2 of them are hard to get to. The bumper needs to come off as well but it is only held on with 4 Philips head screws. My Moho has a lower spoiler made of some kind of plastic and is riveted on. It does not need to come off if you have someone to hp you lifting the radiator out. I didn't so I drilled out the rivets to avoid damaging it while removing the radiator. It was along weekend project for me but I could do it fAster if I ever have to do it again. Good luck and take lots of pictures to aid getting it all back together. If would like to see more pictures of my project let me know.
