Old 11-11-2014, 08:35 PM   #1
airmack
1989 37' Airstream 370
Howick , Quebec
Engine change
Has anyone ever changed a motor on a 80's airstream motorhome. My Ford 460 is on the brink. Would like to hear from anyone who has done the job hands on. Thanks Malcolm Peddie
airmack is offline   Reply With Quote
Old 11-11-2014, 09:12 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The way I did it was to remove the transmission, flywheel, exhaust manifolds, oil pan and pump and engine mounts to gain barely enough clearance to pull it through the front. Should go without saying you will need to remove the carb and distributor as well.
Old 11-13-2014, 06:58 PM   #3
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
A Ford 460 in a Classic P30 Airstream?????
Not wanting to question your sanity but how did that motor end up in there?
Cheers
Tony
Old 11-13-2014, 10:09 PM   #4
airmack
Howick , Quebec
Engine
Hi I have a 370LE and they all came with 460's in a gillig chasis not the P30
Old 11-14-2014, 12:56 AM   #5
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
marshfield , Massachusetts
airmack,
I just bought a 370 and could imagine upgrading the motor at some point.
Somewhere in the archives there's a thread that discusses a diesel conversion in a 370 but I can't recall the name of the fellow that did it. Since there were supposedly only 15-18 of these coaches ever built, one of two of which have dropped by the wayside, the knowledge base pertaining to chassis and running gear is pretty limited. Please keep this post alive as you proceed with the project. I'll be closely following your progress.
Just curious, what's the history of your coach?
Charly
streamquest is offline   Reply With Quote
Old 11-14-2014, 01:52 PM   #6
Dazed and Confused
Isuzusweet's Avatar
My bad I forgot about that year and the 370's.
Cheers
Tony
Old 11-15-2014, 08:23 AM   #7
airmack
Howick , Quebec
370le
Originally Posted by streamquest View Post
airmack,
Charly
Hi Charly I've found out that there were 33 made and mine was sold new in Texas. Malcolm
Old 11-18-2014, 12:58 AM   #8
1936 20' Clipper
1947 22' Liner
Curtis Wright
Hi Malcolm,
Just curious, what was your source for that production quantity? It's about double the number that I've always heard. Fred's Archive is probably the source of the number that I'm thinking of.
Maybe we can compare serial numbers or whatever to verify a range of 370 models produced during that year, although I'm not certain if the different models (325, 345, 370) were uniquely and sequentially numbered.
Anyone know the answer?
Charly
Old 11-18-2014, 07:57 AM   #9
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Here's the Cummins swap thread
http://www.airforums.com/forums/f311...cle-38432.html
Old 11-19-2014, 07:51 AM   #10
airmack
Howick , Quebec
370
Hi Charly. When I bought the 370 there was an inter office letter dated Feb 1989, from Airstream to Gillig Corp listing the Gillig frame serial #s to the corresponding Airstream body serial #s and the dealers to where the motorhomes were sold. Also some of the 370's sold have the original owners name, I checked and contacted the family of mine to see if was true, turned out to be right. Also the letter is from Fredrick Foth (Airstream director of operations) to Don Dickerson Gillig Corp, and signed in ink by hand by Fredrick Foth. I'm not computer savvy but will try to get a copy loaded and posted. I beleive this to be an important document for Airstream history. Malcolm Peddie
Old 11-19-2014, 11:33 PM   #11
1936 20' Clipper
1947 22' Liner
Curtis Wright
370
Malcolm,
That is a really interesting piece of information. While it suggests that there are potentially twice as many 370's running around as anyone may have thought, it also puts an absolute cap on the number that were (or might have been) produced. I'd love to see that piece of correspondence. Does it indicate that all of the Gillig chassis allocated to Airstream were actually converted into finished 370 motorhomes, or was it simply an agreement to make that many available?
What do you think about starting a registry of 370s and trying to figure out where they all are?
Charly
Old 11-21-2014, 06:25 AM   #12
airmack
Howick , Quebec
370 info
Hi Charly Thanks for responding, I'm not good at uploading paper to computer but my kids are, I'll be seeing them in the beginning of next week. I'm very excited that someone is interested in my find. I will get a copy of these papers to you asap. A 370 registry sounds like a great idea, except I have no idea how to start one. Maybe with your help we could start one. Thanks again. Malcolm
Old 11-21-2014, 03:06 PM   #13
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
also interested, please share.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 11-23-2014, 05:13 PM   #14
airmack
Howick , Quebec
370 le
Hi Thanks for the interest I'll keep you posted and try to get the letter online this week. Malcolm Peddie
310 engine change diesel to gas, gearing question tevake Mechanics Corner - Engines, Transmission & More... 4 10-11-2013 06:16 PM
Losing engine elec. engine dies while driving ccgartman Airstream Motorhome Forums 4 12-10-2011 09:46 AM
Tranny 'flush' or Filter change Sav'h Steve Mechanics Corner - Engines, Transmission & More... 18 04-02-2004 09:22 PM
Ideas to change the floor plan / interieur of a 1979 Safari Hans General Interior Topics 0 12-23-2002 11:58 AM
Partial Floor change winner Floor Finishes 12 07-22-2002 07:08 AM
