Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 10-19-2006, 06:22 AM   #1
Howard Lefkowitz
Profile:
Engine Air Conditioner
I need the R12 freon capacity for the 1990 through 1995 454 Classic Motor Home. Thanks.
Howard Lefkowitz is offline   Reply With Quote
Old 10-19-2006, 10:58 AM   #2
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Starting in 1994, R134A was the legally mandated refrigerant. If you want to convert, when you find the specification for the R12, and if you can't find the R134A weight capacity, R134A is 80% of the weight of R12.
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 10-19-2006, 11:49 AM   #3
swebster
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
Terry,
You really do know too much about this stuff
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 10-19-2006, 08:03 PM   #4
Nye Thatcher
Nye Thatcher's Avatar
Profile:
I think at that time they were still using the G.M. receiver/dryer with the sight glass. If so, clean it off and charge until the bubbles stop. At this point add five more ounces. You may need a mirror to watch the flow under the sight glass.The pressure reading on your low side will be around 40 p.s.i. Good Luck.
Nye
Nye Thatcher is offline   Reply With Quote
Old 10-21-2006, 09:12 AM   #5
Howard Lefkowitz
Profile:
I want to convert to Redtek but the original R12 charge is not marked anywhere. I don't know why Chevrolet or Airstream did not provide the tune-up, freon, fluid levels etc. for these Motor Homes. The specs are different for each year and model and it would be nice to know what is needed for repairs. The Chevrolet Motor Home books provide some of the info but not all.
Old 10-21-2006, 03:06 PM   #6
noiva
noiva's Avatar
Profile:  Chesapeake , Virginia
Images: 46
Sounds all too familiar. My Blimp has a Ford engine, and it's manual gives virtually no useful information. I have had very good success going to NAPA or Pep Boys and asking for engine things for a 1987 (last year of carbs on vans) E-350 Van with the 460 engine. So far every part or capacity has be correct. I even bought an after-market book for that year van, and it's full of useful info. May be an option for a Chevy also?
Best,
Tim
No More MoHo
1989 34X
2003 Suburban 2500
AIR # 5648
noiva is offline   Reply With Quote
Old 10-23-2006, 12:29 PM   #7
Howard Lefkowitz
Profile:
And the answer is -------------
The consensus is between 30 and 35 oz of R-12 for the 1990 345 Models.
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-09-2005 02:53 PM
454 engine questions Curtis-79MH Mechanics Corner - Engines, Transmission & More... 10 10-06-2003 06:22 AM
Heater and Air Conditioner Jeb Airstream Motorhome Forums 2 10-22-2002 07:45 AM
Air conditioner drain jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-10-2002 01:52 AM
Air conditioner compressor rdm Mechanics Corner - Engines, Transmission & More... 2 05-13-2002 06:54 AM
