Old 08-18-2016, 10:05 AM   #1
t7389sg's Avatar
1991 35' Airstream 350
Laurel , Maryland
Energenius leaked out all its smoke
Can some here show me how to wire the new transfer switch?
new switch
old switch
I do know what the pairs of wires coming out to the back are but I don't know what wire is incoming to the switch and which one goes back to the panel on the front.
ID:	269367   Click image for larger version
t7389sg is offline   Reply With Quote
Old 08-18-2016, 11:59 AM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
There are YouTube videos on how to replace the magic smoke. Saves big money, small effort.
Happy Thursday!
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 08-19-2016, 08:31 AM   #3
t7389sg's Avatar
Laurel , Maryland
figured it out
in case anybody else ever has to replace the magnetic transfer switch in their Energenius.
Old 08-21-2016, 06:32 PM   #4
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
Honestly, I would recommend getting rid of this liability asap! They tend to melt.
SebasSF is offline   Reply With Quote
Old 08-22-2016, 09:17 AM   #5
t7389sg's Avatar
Laurel , Maryland
it's gone
yes of course. I replaced all the guts with a Boondocker 75 amp charger /converter mounted on the inner wheel well under the big drawer so I could access it if I ever needed to replace a fuse but kept the panel with the fuses and the breakers to protect all the wiring in the coach. I left the transfer switch because I didn't want to unplug the shore power before I started the generator. But I noticed the transfer relay was getting hot after running the roof air for a few hours so now it has been replaced with a Parallax ATS line generator switch. Nice unit and fits inside of the Energenius because I emptied that box from all the singed circuit boards and that enormous transformer.
Old 08-22-2016, 05:56 PM   #6
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 11
Wire size is too small, you can see three connections have been stressed. It really should not be setup for 30Amps but for the available current, which would be at least twice as high.
Time to change...
sgschwend is offline   Reply With Quote
Old 08-23-2016, 09:17 AM   #7
Center Moriches , New York
Would this help????
http://www3.telus.net/bc_triumph_registry/smoke.htm
NY24 is offline   Reply With Quote
Energenius replacement. SebasSF Classic Motorhomes 9 06-06-2014 03:38 PM
EnerGenius in our MH burns up 3 Dog Nite Batteries, Univolts, Converters & Inverters 7 06-02-2014 10:11 PM
Smoke, Smoke Everywhere ncbambi 2008 Safari SE 14 07-25-2010 07:28 PM
Mysterious leak-It leaked,now it doesn't? shinybean Fresh Water Systems 2 06-18-2007 10:02 PM
Energenius Kaput? 89_370LE Classic Motorhomes 9 04-26-2005 05:56 PM
