Old 09-22-2016, 11:01 AM   #1
1994 36' Classic 36 Diesel
Morton , Illinois
Electrical Problems on a '94 Classic diesel pusher
Just got our '94 Classic diesel pusher MH out of storage for a trip. It had been put up for two weeks, and the batteries were disconnected. We reconnected both the coach and engine batteries, and the coach started without a problem. When we got home, the hydraulic levelers wouldn't drop. The panel lights came on, and we could hear sounds from the levelers, then the low battery indicator on the leveler panel came on, and nothing further would happen. The levelers did not extend. Thinking it was due to low coach batteries, we tried to start the generator, only to find it will not start. We left the MH plugged into shore power over night, with no better results. When unplugged, the test panel is dark, but the cabin lights work, water pump and fridge all work. When on shore power, the test panel works, and the battery panel lights shows full charge. Tester shows current coming out of the batteries. We are stymied! Has anyone had experience like this, or have suggestions for a solution?
Looking Forward to Days on the Road
Connie 'n Bruce
CLKIESER is offline   Reply With Quote
Old 09-22-2016, 05:13 PM   #2
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
On my 310, the generator starts off the chassis battery. I dont have levelers. Are they typically run off the coach batteries or chassis battery?
mayco is offline   Reply With Quote
Old 09-22-2016, 07:38 PM   #3
Morton , Illinois
On ours the genset and levelers start off the coach batteries.
Connie 'n Bruce
Old 09-22-2016, 07:44 PM   #4
Morton , Illinois
Success . sometimes it is just too simple. The connection after the shutoff switch on the house batteries was just a little bit loose. cleaned and tightened it and everything is working well.
Connie 'n Bruce
Old 09-22-2016, 07:53 PM   #5
Heck, that was just to darn easy!
I gotta admit it's always nice when it turns out to be something simple.
Old 09-23-2016, 04:23 AM   #6
mayco's Avatar
Wooohooo. I had a rear turn signal acting up last weekend. The inside and outside lights on the cluster were flashing alternately. Supposed to flash together. I immediately thought that it HAD to be a bad ground somewhere because of how weird it was. Sure enough, pulled the bulbs and there was just enough white corrosion on the outside of the bulb base it wasnt grounding properly. Cleaned em up and used some dialectric grease, bingo! Another one, TOO EASY.
Old 09-23-2016, 04:51 PM   #7
Don't get to cocky there Mike.....that's just asking for trouble!
Old 09-23-2016, 06:54 PM   #8
1995 36' Classic 36
Ludington , Michigan
I've seen more problems caused by battery disconnect switches that they have cured. I use latched power solenoids. They require 12 volts to switch on and off but draw 0 current when magnetically latched on or off. Only way to go in my book.
Kota is offline   Reply With Quote
Old 09-24-2016, 10:32 AM   #9
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
I had some very odd electrical problems with my 94 diesel just before a long planned road trip. Turned out to be he battery combiner switch on the dashboard in the on or "combined" position.
SebasSF is offline   Reply With Quote
Old 09-24-2016, 08:18 PM   #10
mayco's Avatar
Cocky!!!!!! This beast has humbled me in so many countless manner of ways! Nawwwww, I was expecting the worst with my turn signal and when it ended up being such an easy fix I thought......well, like you said TOO EASY! no cocky here thats for sure, did you hear that AIRSTREAM GODS? I bow to your power!
Classic Diesel Pusher :: 1995 Airstream Classic 360 Diesel Pusher Kota Airstream Registry Discussions 1 10-08-2011 04:47 PM
Problems Problems Problems pjude General Motorhome Topics 6 09-03-2007 07:25 AM
Need an inspection in Houston. 95 Diesel Pusher Classic Griffin WBCCI Forum 1 03-19-2007 07:56 PM
