Old 04-22-2016, 01:39 PM   #1
Surprise's Avatar
1984 31' Airstream310
Surprise , Arizona
electric fuel pump fuse block location
I was tinkering around and noticed my electric fuel pump cutoff relay was powered from the "gauges" fuse block location. No wonder my gauges never sat still. I'm looking for info on everybody else's electric fuel pump fuse block location. I understand it should be to an "ignition" terminal.
Surprise is offline   Reply With Quote
Old 04-22-2016, 02:33 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If no one knows where it is you can wire it yourself. Go to the fuse panel and check for an empty location that is ignition controlled. put in the fuse value you want and wire the pump to it.
If there is not an empty fuse slot pick any ignition controlled location and wire a relay coil off and the other side to ground. Now feed on side of the normally open side of the relay from the 12 feed to the panel and wire an inline fuse from the other side of the normally open contact to the pump.
2004 Excursion 4x4
fuel pump fuse and/or relay location uhmazzin1 Electrical - Systems, Generators, Batteries & Solar 6 06-20-2013 01:31 PM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
Rear fuel pump fuse guy99 Mechanics Corner - Engines, Transmission & More... 2 10-07-2004 05:33 PM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
