Old 07-01-2006, 09:43 AM   #1
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
Easy fix for Door Problems
When your entry door no longer closes correctly, look at the hinges. The bottom of the hinge contains a washer which acts as a bearing when the door swings. This washer wears out and is often totally gone. If the stripes on your door don't line up with the body striping, you need a new washer. Get some 1/4 inch nylon washers from Lowe's or somewhere & nip out a small segment with cutters. Lift the door (having a friend is helpful here) and hold it up while you push the cut washer into the space between the door part and the body part of the hinge. Sometimes you need two or even three washers to bring the door up to the right level. Use Nylon and not any hard material like stainless - that would eat its way into the cast aluminum of the hinge body and then you have a new hinge to buy.
Jamie
jking is offline   Reply With Quote
Old 07-01-2006, 01:16 PM   #2
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Thanks for the tip, most of us do have the saggy door syndrome and this may do the trick.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 09:59 PM
Broken Lite Shade Fix wagsrp General Interior Topics 1 10-13-2002 09:11 AM
How do you fix the entry step. rdm Airstream Motorhome Forums 2 07-14-2002 09:16 PM
wiring fix? ALANSD Airstream Motorhome Forums 9 06-20-2002 07:40 AM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 12:32 AM
