Old 08-22-2006, 11:05 AM   #15
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Take a look at this, what else would be required?
http://cgi.ebay.com/ebaymotors/2006-...spagenameZWDVW
This is a 4x4 which you wouldn't want but 2WD versions come up with some frequency. If you were working with a local wrecking yard seems like you could make a deal for the engine, transmission, and all required electronics/wiring.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 08-22-2006, 11:25 AM   #16
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Look at Ebay item #190023166496
A little cheaper with a 4L80E transmission. Might be a little less complicated, and certainly cheaper.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 08-22-2006, 01:38 PM   #17
2006 30' Classic
Farmington , New Mexico
Images: 14
Quote ------ Take a look at this, what else would be required
Guy99--asuming this is as advertised it would be a good buy. Still it is a long way from all that's needed for conversion. A complete cooling system, an intercooler, exhaust system, complete fuel system-tank-fuel lines -pump-cooler etc. Also the drive line will have to be mated to Al trans. a rear extention for trans after transfercase is removed. While what thats is here is a big chunk ,it's still only half of whats needed $$$$$ wise. This would be a great buy for someone who already has a Duramax with high mileage and was looking to update their vehicle. I also would like to see the vehicle this came out of. Was it a head on?? A floaded vehilce,? thoughts--pieman
Mike Lewis is offline   Reply With Quote
Old 08-22-2006, 01:51 PM   #18
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
I read a series of posts a while back, on dieselplace.com, about some folks that were attempting to power an airboat with a Duramax. They were going to direct drive or use a gear reduction unit between the engine and propeller. It seems that they could not get the engine to run, because the Engine Control Module did not have a Transmission Control Module to "talk to". The ECM said in effect, "If I don't have a transmission, there's no point in me even starting". As I recall, no body could figure out how to "fool" the ECM into thinking it had a TCM connected to it. GM would offer no help, either.
Such is life in the age of computers.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Duramax Suburban! Pick Tow Vehicles 14 05-22-2006 12:17 PM
New Tow Vehicle Option - Duramax Van j54mark Tow Vehicles 5 03-25-2006 04:53 PM
DuraMax Info Over59 Tow Vehicles 17 08-06-2005 09:31 PM
Help! Duramax vs. Quadrasteer Hit'the'road Tow Vehicles 24 10-14-2004 05:03 PM
Duramax towing question Mark Wiltrakis Tow Vehicles 6 11-07-2003 12:24 PM
