Old 02-27-2007, 06:51 AM   #1
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Images: 37
Question Dupont Paint number??
Does anyone know the Dupont paint number for the gray used on our coaches in the 80's?
I have a 82 310 MoHo
Thanks for any info.
Chris
Chris & Brenda, Members of the Christian Motorcyclists Association
AIR Member 12654
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (263,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 02-27-2007, 06:55 AM   #2
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Hello .. Funny you should ask. I picked up the paint list from Airstream at the FSR.. here it is Dupont centari 44146-A Metallic Grey.. Hope this helps..
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 02-27-2007, 06:59 AM   #3
cmadmaxman's Avatar
Images: 37
Thumbs up Thanks
Yes that should do it. I will check with my Dupont place here and check this out today!
Thanks for the quick reply
I have the front windows out and want to paint them before installing them back with all the new channel.
AIR Member 12654
1982 310 MoHo
Old 02-27-2007, 10:37 AM   #4
1982 28' Airstream 280
Norfolk , Virginia
Chris,
How about some pictures of your coach and the methods and materials you used in round tripping your windows?
Steve
Geophilist is offline   Reply With Quote
Old 02-27-2007, 11:14 AM   #5
cmadmaxman's Avatar
Images: 37
Be glad to. Will get some photos and post them along with some things that I found out that has not been talked about here.
I have been using Cirtrs Strip (SP) from Lowes or Home Depot to take the brushed on flat black that a PO had put on the window frames! Not trying to take it all the way down to the alum. but, most of it is. I'm taking all of the clear coat off the alum., so don't have to worry about getting it on the skin. I will be using a alum. etching primer before putting on the color.
I have talked to our Dupont paint guy, and said they do not make the Centari paint any longer. There is still some of it out there, but he don't have it. He is trying to cross over the number now and will get back with me on it. Will post when I hear something.
AIR Member 12654
1982 310 MoHo
Old 02-27-2007, 12:12 PM   #6
1979 30' Argosy
The Airstream PT# 3601512..... Maybe Airstream still carry this.. this number was in another column. Hope that this helps.. can he crossmatch it to an Imron paint??
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 02-27-2007, 06:56 PM   #7
cmadmaxman's Avatar
Images: 37
Dupont number
I heard from my Dupont guy. He said that Dupont has it in the acrylic enamel. Said that I will need to use hardener and thiner with the product. The only diff. is that Dupont drops the -A for the paint number.
So the paint number is 44146 Metallic Grey.
I don't have to worry about matching, everything will be painted new that was painted. 25 years sitting outside has even taken its toll on the lower skirt of the coach as well.
Here is some photos of the window frame striped. Also the product that I have been using. My paint guy said to use a etching primer before applying the paint.
On another note, I have found a small drain on the inside track of the front windows. This would have been a great idea airstream came up with, but a bad install has made it useless! When they put the trim around the window, they drilled holes in the bottom of the channel, so if water gets in, it will just run out of the hole for the pop-rivet!
Here is a couple of pic's of that.
ID:	33136   Click image for larger version
ID:	33138   Click image for larger version
AIR Member 12654
1982 310 MoHo
Old 02-27-2007, 07:12 PM   #8
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
Smile Just in time
My 250 goes in the paint shop next week to get just the grey done and all new pin stripping. Your Dupont information came just at the right time!! Thanks Cmadmaxman.
Pop Rivet is offline   Reply With Quote
Old 02-27-2007, 08:53 PM   #9
cmadmaxman's Avatar
Images: 37
You better let us see it when you get it back!!
Have been working taking off the pin striping, just not sure what we want to put back on!?
AIR Member 12654
1982 310 MoHo
Old 03-01-2007, 10:43 AM   #10
Norfolk , Virginia
Chris,
Thanks for the pictures, it cleared up my thinking. I had thought that you were removing the windshields rather than the driver's/passenger's side sliding windows.
What did you use to remove the stripes? It seems like you can really hurt the baby if you do it wrong.
Steve
Old 03-02-2007, 12:49 PM   #11
cmadmaxman's Avatar
Images: 37
I use the Cistristrip. I don't worry about the clear coat on the alum., I want it off anyway for polishing.
Other than that a heat gun, and very easy with the plastic scraper. You realy find how soft the alum. is after working with it like I have been doing. After polished, you can rub your finger accross it and scratch the polish job!
AIR Member 12654
1982 310 MoHo
Old 03-05-2007, 06:11 AM   #12
Klaus from Germany
Klaus Keitel's Avatar
Nuernberg , Bayern
Paint number
Hello from Germany,
I have also a paint number question.
I need the code of the metallic blue on my 1991 250CL
Who can help me ?
Regards Klaus from Germany
Name:	Airstream 250 CL.jpg
Klaus Keitel is offline   Reply With Quote
Old 03-05-2007, 06:47 AM   #13
Pop Rivet's Avatar
Altoona , Georgia
Blue paint
Klaus, I have never seen a 1991 classic motorhome with blue paint. Most have maroon where yours has blue. Attached is a photo of my 1990.
Name:	Winhall campgound 003.jpg
Old 03-05-2007, 07:13 AM   #14
Klaus from Germany
Nuernberg , Bayern
Blue paint
Hello David,
Thank you for reply.
The blue paint is the factory one.
I will be honest to you. I like the crimson more.
But I can’t change cause of the colour of the
awning’s.
Regards Klaus
Name:	Airstream 250CLm-Zipdee.jpg
Blue paint uwe Clearcoat, Exterior Paint & Trim 52 09-17-2014 07:41 PM
Dark grey bottom paint. apple 1 Clearcoat, Exterior Paint & Trim 5 08-07-2009 11:23 AM
Paint Repair Primer Howard Lefkowitz Clearcoat, Exterior Paint & Trim 2 08-25-2002 11:56 AM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 05:39 PM
Help...re Paint GOOFUP Cat Clearcoat, Exterior Paint & Trim 3 04-18-2002 08:14 PM
