Old 06-28-2007, 08:03 PM   #1
1986 34.5' Airstream 345
Tyler , Texas
Dual air
HI! I recenty bought a 86 345 and need some help! This unit is designed to only run one roof air at a time. I can run both if hooked to shore power and also run the genset. Being in TEXAS we need to run both units either on shore or on the genset. How do and where do I rewire the units so that I can run both at the same time?
Pete
pjude is offline   Reply With Quote
Old 06-28-2007, 09:39 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Dual Air
Hi Pete,
Check out the thread at http://www.airforums.com/forums/f427...fit-33581.html Dual Air Retrofit. I posted a question about adding a second AC unit to my Excella and the responses and advice have been excellent.
Baughan
Old 06-28-2007, 09:44 PM   #3
1983 34' Excella
1967 24' Tradewind
Images: 32
Rivet
Originally Posted by vswingfield
Hi Pete,
Baughan
OK, it's late and I have been struggling with my old Coleman this evenging. The unit quit at 6:30 and it took me till 8:45 to get it working again. Needs a new switch on the unit. Have already replace the thermostat on the unit. Have only owned the trailer since January, the AC is the only negative so far.
That should read
Vaughan not Baughan
Old 06-29-2007, 05:44 AM   #4
Tyler , Texas
Dual air
This 345 is equiped with 2 air units but I have to move a switch in the upper cabinet to run either the front air or the rear air. I need to run both units at the same time. I have an Onan 7000 generator so I have the amps needed but need to wire both units to the genset....any advice?
Pete
Old 06-29-2007, 07:00 AM   #5
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
Guys, the roof A/C draws 18 amps average when the compressor starts (sometimes as much as 23 amps). Your coach is wired for a total of 30 amps draw through the electric hookup wire. There is no safe way to use both a/c units on 'shore power'. Yoou can overheat wires and start fires. On generator power both will operate as factory wired - designed that way. - Jamie
jking is offline   Reply With Quote
Old 06-29-2007, 07:01 AM   #6
Central , Mississippi
My SOB RV had a similar setup except the AC's would both run off of the gen, but only the front off of shore power. I located the wiring for the rear AC an installed a plug and socket. When I got to a camp, I would run a seperate extension cord from the newly installed rear AC plug to the 15A outlet on the camp hookup. The rest of the RV ran off of the standard 30A setup. Easier that rewiring the whole mess for 50A
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
HiHoAgRV is online now   Reply With Quote
Old 06-29-2007, 11:39 AM   #7
Tyler , Texas
Jking: I cannot run both units off of the genset. A switch above the micro limits the use to either the front or the rear AC except when I plug into shore power then I can use the front air from shore power and the rear from the genset...In Texas I need to run both from the genset while traveling.
Pete
Old 06-29-2007, 12:15 PM   #8
In my SOB, the transfer switch had the air's tied to seperate contacts. When pulled in, both airs were tied to the genset. When not pulled in, the rear air was dropped off (no feed to contact 2 from shore power). The answer to your problem lies in properly wiring of the transfer switch. I am making an assumption your unit has an automatic transfer switch and you don't have to replug stuff to run off of the generator. Depending on where the feeds are, it could be a pretty big job just routing the wires.
If you want both airs to run at camp you will need to convert to 50 amp or use a trick like I posted above.
Old 06-29-2007, 01:00 PM   #9
Pete
Pete,
I know what you're dealing with, we have an 84 310 (and your 345) that is set up the same. On our 310 there is an automatic transfer switch under the passenger side rear closet. Under that closet you should find a circuit breaker box and a transfer switch box. The circuit breaker box is for the circuit going from the Genset to the rear air. The way the generator is setup is it will have two 120 vac circuits. One circuit is ONLY for the rear air and nothing else. The other circuit feeds the rest of the coach. In order to run the rear ac while on shore power you will need to break the line from just before the ciruit breaker where it comes from the generator that feeds the rear air and have a seperate connector that you feed directly from a 20 amp shore power ciruit. I'm going to be installing a double pole double throw switch so I can just select shore power or generator power for the rear air.
If you give me some time I can work up a sketch of what you're going to need to do.
Rest asured there is a way to do what you want but it will take a little rewiring. Nothing major fortunately.
bkahler is online now   Reply With Quote
Old 06-29-2007, 01:38 PM   #10
Tyler , Texas
Dual Air
bkahler...Thanks for your info but I'm being misunderstood. I can run both the units pluged into shore power if I also turn on the genset to run the rear air. What I want to do is run both units off of the 7000W Onan while traveling which I cannot do now and it is unbarable in the rear of the coach when the temps in Texas are in the 90's.
Old 06-29-2007, 02:32 PM   #11
Oops! Sorry about that. What you're asking for is the way the system was originaly designed. It sounds like the circuit breaker for the rear air only on the genset is turned off or tripped. There may actually be two circuit breakers involved. One on the genset and one on the passenger side probably under the closet. Poke around under the closet and see if you can find a single circuit breaker. Assuming you find it check to make sure its turned on. Also on the genset there is likely to be a circuit breaker for each circuit. Check to see that it is turned on and not off or tripped.
I'll look in my service manual which covers the 345 as well and see if it mentions anything specific about the 345.
Good luck!
Old 06-29-2007, 05:29 PM   #12
Tyler , Texas
Dual Air
Thank you for your interest and advice...it was a breaker on the genset that was tripped. The previous owner stated that it was not possible to run both units on the coach but I felt like there had to be a way since this thing gets sweltering here in East Texas. I also find it strange that Airstream would only put in 30 amp power. I have a 1973 Travco that I refurbished and it has 50 amp stock from the factory. Once again many thanks and I hope alls well
Pete
Old 06-29-2007, 06:10 PM   #13
Pete
Cool! (pun intended)
Glad I could help. I've received so much help from this forum that its nice to give something back.
I guess the 30 amp system was designed before most places had 50 amp service available.
We're not too far north of you here in Arkansas and just standing inside our MH without the air on and I start dripping sweat.
Old 07-02-2007, 09:07 PM   #14
dual a/c
On my 345 i had an electronic relay added to allow for me to plug in the coach power(for one of the ac units)and also plug in another 20 amp feed so that I can run both units when camping without having to run the generator. The relay prevents potential electrical problems with the selection switch. System works great and saves wear on generator. Most campgrounds have the 30 amp plug along with another 15-20 amp outlets. I also had an adapter plug built so that if the campground has a 50 amp plug then i can plug my 30 and the 20 into my adapter then plug the adapter into the 50.
mlmarch is offline   Reply With Quote
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
Rear Air bags PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 24 11-12-2007 06:02 PM
Heater and Air Conditioner Jeb Airstream Motorhome Forums 2 10-22-2002 07:45 AM
air horns uncleneal Airstream Motorhome Forums 1 08-16-2002 07:22 AM
Air streams in New York area?!? mitchm71 Our Community 0 07-25-2002 09:33 AM
