12-02-2013, 08:58 PM
2002 25' Safari
1977 20' Argosy 20
northern valley
, new jersey
Originally Posted by arden_dean
Take a look and let me know what you think.
"nope."
icocbw, but the part I think you are seeking is known as "fuzzy schlegel", pictured here - http://www.inlandrv.com/catalog/images/34696.JPG and here - Inland RV Center Inc.
in addition, there are three or four other seals / gaskets / trims used around the motorhome windows that you might also consider.
I'd try Inland RV or ODM RV for help in getting all that you might need.
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
https://defendwally.org/
12-03-2013, 04:59 PM
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
try this , its easy to work with :
AS1268 Flexible Flocked Lining All-Rubber | Hi-Tech Glazing Supplies
you slice the back every 1/4" to go around the corners.
AIR #13
12-03-2013, 05:38 PM
1985 34.5' Airstream 345
Centennial
I'm currently having a heck of a time getting either of the above materials to work. Have used the Inland RV stuff before and it worked great on a '79 29' Excella. It's too thick for our 345 and won't let the window slide or won't seat properly in the back of channel. The same with the beaded window channel material. It's almost as if the window opening shrank having the deteriorated window felt so bad for so long. Yours might be different and I would try the Inland RV channel 1st. I'm looking for thinner material. It's pretty easy if you know how to do it. If you need help let me know.
12-03-2013, 05:43 PM
Corona
The current "schlegal channel" from Airstream, is exactly the same as the original.
I would suggest that until the new channel gets a few "miles", that you spray the schlegal with some silicone spray.
That for sure will make the windows slide easier.
12-03-2013, 05:56 PM
Centennial
I would not try to do the job with this stuff. It won't be flexible enough for what you're trying to do. BTW, the cab windows call for 4 different seals.
1. Window channel seal (Inland RV Schlegal(sp?) probably best choice)
2. Fuzzy window channel (bug seal, hard to find the correct one, still looking)
3. Vertical window seal Odmrv.com #684916
4. Wrap around seal Odmrv.com #685044
12-03-2013, 06:47 PM
1984 31' Airstream310
Honokaa
, Hawaii
Here is a thread on the steps involved in the job:
http://www.airforums.com/forums/f160...ment-9584.html
I did not have to remove the lock on my windows when I did this job, otherwise it went just as described in the thread. I ordered the various replacement parts from Inland, everything worked and they knew what I needed.
However, after doing the job the driver's window would not close all the way. I was not sure that it had ever closed all the way, and was convinced that the window frame needed to be pushed in to fix it. Fortunately, I did not do that. Stopped at the mothership in Jackson Center while in that part of the country, an old time tech tweaked the seal with what he told me was a wooden shim and a hammer, and a half hour later we were on our way with a closed window.
12-04-2013, 09:47 PM
1986 34.5' Airstream 345
topeka
, Kansas
have u used this?
Originally Posted by PeterH-Airstreamer
Do u have pics?
“The world is a book and those who do not travel read only one page.” – St. Augustine
12-05-2013, 04:01 AM
Corona
Do u have pics?
The correct schlegal window fuzzy channel, does not need to be cut on the backside.
It's made to easily bend in the corners.
It's held in place with the 3M super weatherstrip adhesive.
12-06-2013, 07:40 AM
topeka
, Kansas
Part #?
Do you have a part # and one for the 3m glue?
Thanks for your help.
12-06-2013, 09:34 AM
Corona
Schlegal 34696
Adhesive 51991
12-06-2013, 03:09 PM
topeka
, Kansas
Sweeps
Schlegal 34696
Adhesive 51991
Thanks, you are a huge help. I would also like to replace the sweeps while I have the window apart. Does Inland RV sell them, if so do you know the part number?
12-06-2013, 03:40 PM
Corona
The part numbers are not really needed, should you decide to place an order.
We always have all the motorhome gasket materials.
12-06-2013, 04:00 PM
Corona
What are you calling "sweeps" ?
How about a photo, or a better description.
What does that part do ? Where is it mounted ?
12-06-2013, 05:05 PM
topeka
, Kansas
parts ordered
vertical lip #34713,
Fuzzy Schiegle # 34696,
thin Seal # 34708,
glue # 51991
Thanks !!!
12-06-2013, 05:09 PM
topeka
, Kansas
Sweep
Sweeps are what they are called on a car. In this case its the Vertical lip Seal.
12-06-2013, 06:00 PM
Corona
Thanks.
12-06-2013, 11:12 PM
Centennial
Andy,
He's still missing what you call "Bug shield." That's the 4th seal needed.
12-07-2013, 05:38 AM
topeka
, Kansas
Screen
Andy,
I was told that was for a screen, there's no screen on the front windows.
do I need them?
12-07-2013, 08:41 AM
Corona
do I need them?
Not really.
But, we have it anyways.
