Old 12-02-2013, 08:40 PM   #1
1986 34.5' Airstream 345
topeka , Kansas
Images: 26
drivers window felt? 86 345
I have an 86 345. It needs new window felt, I think this will work.
http://www.dkhardware.com/product-25635-y62096-beaded-flexible-snap-in-channel-for-1954-1966-gm-and-ford-96-length.html
Take a look and let me know what you think. Also, If you have replaced your window felt please share and provide details like part numbers.
arden_dean is offline   Reply With Quote
Old 12-02-2013, 08:58 PM   #2
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
"nope."
icocbw, but the part I think you are seeking is known as "fuzzy schlegel", pictured here - http://www.inlandrv.com/catalog/images/34696.JPG and here - Inland RV Center Inc.
in addition, there are three or four other seals / gaskets / trims used around the motorhome windows that you might also consider.
I'd try Inland RV or ODM RV for help in getting all that you might need.
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 12-03-2013, 04:59 PM   #3
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
try this , its easy to work with :
AS1268 Flexible Flocked Lining All-Rubber | Hi-Tech Glazing Supplies
you slice the back every 1/4" to go around the corners.
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 12-03-2013, 05:38 PM   #4
1985 34.5' Airstream 345
Centennial , Colorado
I'm currently having a heck of a time getting either of the above materials to work. Have used the Inland RV stuff before and it worked great on a '79 29' Excella. It's too thick for our 345 and won't let the window slide or won't seat properly in the back of channel. The same with the beaded window channel material. It's almost as if the window opening shrank having the deteriorated window felt so bad for so long. Yours might be different and I would try the Inland RV channel 1st. I'm looking for thinner material. It's pretty easy if you know how to do it. If you need help let me know.
Heirstream is offline   Reply With Quote
Old 12-03-2013, 05:43 PM   #5
The current "schlegal channel" from Airstream, is exactly the same as the original.
I would suggest that until the new channel gets a few "miles", that you spray the schlegal with some silicone spray.
That for sure will make the windows slide easier.
Old 12-03-2013, 05:56 PM   #6
I would not try to do the job with this stuff. It won't be flexible enough for what you're trying to do. BTW, the cab windows call for 4 different seals.
1. Window channel seal (Inland RV Schlegal(sp?) probably best choice)
2. Fuzzy window channel (bug seal, hard to find the correct one, still looking)
3. Vertical window seal Odmrv.com #684916
4. Wrap around seal Odmrv.com #685044
Old 12-03-2013, 06:47 PM   #7
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Here is a thread on the steps involved in the job:
http://www.airforums.com/forums/f160...ment-9584.html
I did not have to remove the lock on my windows when I did this job, otherwise it went just as described in the thread. I ordered the various replacement parts from Inland, everything worked and they knew what I needed.
However, after doing the job the driver's window would not close all the way. I was not sure that it had ever closed all the way, and was convinced that the window frame needed to be pushed in to fix it. Fortunately, I did not do that. Stopped at the mothership in Jackson Center while in that part of the country, an old time tech tweaked the seal with what he told me was a wooden shim and a hammer, and a half hour later we were on our way with a closed window.
Waipio Rim is offline   Reply With Quote
Old 12-04-2013, 09:47 PM   #8
topeka , Kansas
Images: 26
have u used this?
Do u have pics?
Old 12-05-2013, 04:01 AM   #9
Do u have pics?
The correct schlegal window fuzzy channel, does not need to be cut on the backside.
It's made to easily bend in the corners.
It's held in place with the 3M super weatherstrip adhesive.
Old 12-06-2013, 07:40 AM   #10
topeka , Kansas
Images: 26
Part #?
Do you have a part # and one for the 3m glue?
Thanks for your help.
Old 12-06-2013, 09:34 AM   #11
Schlegal 34696
Adhesive 51991
Old 12-06-2013, 03:09 PM   #12
topeka , Kansas
Images: 26
Sweeps
Schlegal 34696
Adhesive 51991
Thanks, you are a huge help. I would also like to replace the sweeps while I have the window apart. Does Inland RV sell them, if so do you know the part number?
Old 12-06-2013, 03:40 PM   #13
The part numbers are not really needed, should you decide to place an order.
We always have all the motorhome gasket materials.
Old 12-06-2013, 04:00 PM   #14
What are you calling "sweeps" ?
How about a photo, or a better description.
What does that part do ? Where is it mounted ?
