Old 12-06-2013, 05:05 PM   #15
arden_dean's Avatar
1986 34.5' Airstream 345
topeka , Kansas
Images: 26
parts ordered
vertical lip #34713,
Fuzzy Schiegle # 34696,
thin Seal # 34708,
glue # 51991
Thanks !!!
“The world is a book and those who do not travel read only one page.” – St. Augustine
arden_dean is offline   Reply With Quote
Old 12-06-2013, 05:09 PM   #16
arden_dean's Avatar
topeka , Kansas
Images: 26
Sweep
Originally Posted by Inland RV Center, In View Post
What are you calling "sweeps" ?
How about a photo, or a better description.
What does that part do ? Where is it mounted ?
Sweeps are what they are called on a car. In this case its the Vertical lip Seal.
Old 12-06-2013, 06:00 PM   #17
Thanks.
Old 12-06-2013, 11:12 PM   #18
1985 34.5' Airstream 345
Centennial , Colorado
Andy,
He's still missing what you call "Bug shield." That's the 4th seal needed.
Heirstream is offline   Reply With Quote
Old 12-07-2013, 05:38 AM   #19
arden_dean's Avatar
topeka , Kansas
Images: 26
Screen
Originally Posted by Heirstream View Post
Andy,
I was told that was for a screen, there's no screen on the front windows.
do I need them?
Old 12-07-2013, 08:41 AM   #20
do I need them?
Not really.
But, we have it anyways.
Old 12-07-2013, 11:38 AM   #21
arden_dean's Avatar
topeka , Kansas
Images: 26
install
Not really.
I read some of the post on this, clear as mud. However, it look like there is 2 sections of fuzzy channel. It seems to me I can remove the section on the top front slide the window forward to where the fuzzy channel is removed and then lean the glass in and pull up and in on the glass and it should come out. Remove and replace the other section of fuzzy channel and the vertical lip put the slideing glass back in then replace the upper front section of fuzzy channel.
My question is where does the thin seal go?
Old 12-07-2013, 12:14 PM   #22
Arden_Dean, I PM'd you
