10-18-2018, 07:17 AM
Undereducated AS Newbie
1989 34.5' Airstream 345
Charlotte
, North Carolina
Door won't open without yanking
Couldn't get the door to open. When this occurred the initial time, I thought the key wasn't unlocking the door. After climbing thru the driver window, I discovered there was no issue with the key & locking mechanism. In order to open, it requires jerking on the handle. What is causing this & is it fixable?
I have a 79 Revcon (the MH built by Byam's stepson, John Hall) & it has a nice Kwikset residence door type keyed deadbolt lock. Anyone done an installation of 1 of these on their Airstream?
10-18-2018, 11:58 AM
Churubusco
, Indiana
Sometimes if I'm parked unlevel the body twist will make it difficult to open/close the door, this is compounded if there is dirt on the bottom of the doorjam where the door rubs
Just a thought
1983 Airstream 310 Class A Motorhome
-Rob
10-18-2018, 04:30 PM
1991 25' Airstream 250
Oxford
, Oxfordshire
Is the flyscreen door slightly off, it can buckle and create issues opening the main door
10-18-2018, 11:13 PM
Charlotte
, North Carolina
We are parked in a level lot & have no issues with dirt in the door channel.
The door has no binding or contact issues.
I think the problem is in the lock mechanism, but not sure what the correction might be.
10-19-2018, 03:47 AM
1984 27' Airstream 270
Scotia
, New York
Check to be sure the lock mechanism screws have not backed out. It does not take much to get the door to jam. Mine are always loosing up.
Do not take life too seriously.
You will never get out of it alive.
10-19-2018, 07:00 AM
1993 34' Excella
Estancia
, New Mexico
Check there are no screw heads sticking up in the door frame threshold.
10-19-2018, 09:45 PM
1991 25' Excella
Chino Valley
I suspect that the hinges are sagging. Perhaps they have come loose or they are worn. My bet would be loose hinges. I just repaired mine on my 91 Excella.
10-20-2018, 09:26 AM
Journeyman
2016 25' International
Amherst
, Massachusetts
Make sure your stabilizers aren't down too tight... that can twist the trailer and make the door bind.
10-20-2018, 05:41 PM
Williston
it is usually the strike of the door that causes this it can be realigned but care must be taken the strike has two rivets these must be drilled out and carefully loosen the strike post do not remove or the back channel will fall down and the whole door must be removed. Check this by carefully looking at the door as it closes is it in the center or hitting high or low
10-22-2018, 02:47 AM
Charlotte
, North Carolina
Motor Home, not trailer...sitting on level ground.
How would I check the hinges to determine wear? Since the door is evenly spaced around the frame, would this rule out hinges as an issue?
10-22-2018, 03:29 AM
Oxford
, Oxfordshire
You can tighten the hinge bolts. I think are on the other side of the inner skin so messy job. I wouldn’t get into that until you are certain of the cause
10-22-2018, 11:21 AM
1982 31' Airstream 310
champaign
10-22-2018, 11:32 AM
champaign
The best way I know how to test your hinges is to open the door half way, lift up on the bottom outer edge and feel for any play or movement. Have someone else lift on it while you look at the hinges. You should be able to see if the hinge bolts are loose or if the pin is worn. You need to look at where the hinge attaches both to the door and to the body. If the bolts are loose then you have to access them from the inside, under the interior skin. It's no fun.
