Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 10-18-2018, 07:17 AM   #1
Undereducated AS Newbie
1989 34.5' Airstream 345
Charlotte , North Carolina
Door won't open without yanking
Couldn't get the door to open. When this occurred the initial time, I thought the key wasn't unlocking the door. After climbing thru the driver window, I discovered there was no issue with the key & locking mechanism. In order to open, it requires jerking on the handle. What is causing this & is it fixable?
I have a 79 Revcon (the MH built by Byam's stepson, John Hall) & it has a nice Kwikset residence door type keyed deadbolt lock. Anyone done an installation of 1 of these on their Airstream?
wimpy is offline   Reply With Quote
Old 10-18-2018, 11:58 AM   #2
Magnet18's Avatar
Churubusco , Indiana
Sometimes if I'm parked unlevel the body twist will make it difficult to open/close the door, this is compounded if there is dirt on the bottom of the doorjam where the door rubs
Just a thought
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 10-18-2018, 04:30 PM   #3
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Is the flyscreen door slightly off, it can buckle and create issues opening the main door
Boom Sounds is offline   Reply With Quote
Old 10-18-2018, 11:13 PM   #4
We are parked in a level lot & have no issues with dirt in the door channel.
The door has no binding or contact issues.
I think the problem is in the lock mechanism, but not sure what the correction might be.
Old 10-19-2018, 03:47 AM   #5
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Check to be sure the lock mechanism screws have not backed out. It does not take much to get the door to jam. Mine are always loosing up.
Do not take life too seriously.
You will never get out of it alive.
WayneG is offline   Reply With Quote
Old 10-19-2018, 07:00 AM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Check there are no screw heads sticking up in the door frame threshold.
Old 10-19-2018, 09:45 PM   #7
1991 25' Excella
Chino Valley , Arizona
I suspect that the hinges are sagging. Perhaps they have come loose or they are worn. My bet would be loose hinges. I just repaired mine on my 91 Excella.
Aznomad450 is offline   Reply With Quote
Old 10-20-2018, 09:26 AM   #8
Journeyman
2016 25' International
Amherst , Massachusetts
Make sure your stabilizers aren't down too tight... that can twist the trailer and make the door bind.
thiel is offline   Reply With Quote
Old 10-20-2018, 05:41 PM   #9
Williston , Florida
Cool
it is usually the strike of the door that causes this it can be realigned but care must be taken the strike has two rivets these must be drilled out and carefully loosen the strike post do not remove or the back channel will fall down and the whole door must be removed. Check this by carefully looking at the door as it closes is it in the center or hitting high or low
Deston is offline   Reply With Quote
Old 10-22-2018, 02:47 AM   #10
Motor Home, not trailer...sitting on level ground.
How would I check the hinges to determine wear? Since the door is evenly spaced around the frame, would this rule out hinges as an issue?
Old 10-22-2018, 03:29 AM   #11
You can tighten the hinge bolts. I think are on the other side of the inner skin so messy job. I wouldn’t get into that until you are certain of the cause
Old 10-22-2018, 11:21 AM   #12
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Weird place to post these photos but here ya go Wimpy.
ID:	325945Click image for larger version
ID:	325946Click image for larger version
ID:	325947Click image for larger version
ID:	325948Click image for larger version
ID:	325949Click image for larger version
ID:	325950Click image for larger version
I still don't know how to post pics in a PM. The dpdt camera toggle switch is the black one next to the gear shift. With the rubber cover on the switch I don't even have to look down to use the switch, I can feel it. It was a safety thing to me, instead of reaching up to the monitor every time I want to switch between cameras. That usually happens in heavy traffic when I want to look at the lane to my right.
mayco is offline   Reply With Quote
Old 10-22-2018, 11:32 AM   #13
mayco's Avatar
The best way I know how to test your hinges is to open the door half way, lift up on the bottom outer edge and feel for any play or movement. Have someone else lift on it while you look at the hinges. You should be able to see if the hinge bolts are loose or if the pin is worn. You need to look at where the hinge attaches both to the door and to the body. If the bolts are loose then you have to access them from the inside, under the interior skin. It's no fun.
Bathroom door won’t open from inside Donamigo Doors & Locks 1 08-27-2018 01:22 PM
Door Won't Open Sbb Doors & Locks 14 05-10-2014 04:29 PM
Domestic freezer door won't open!! LiLNomad General Repair Forum 4 08-21-2013 09:10 AM
Outside fresh water door lock won't open willbrackman Exterior Storage Compartments & Access Doors 12 11-02-2011 12:27 AM
Tambour door won't open Rog0525 Cabinets, Counter Tops & Furnishings 9 11-29-2003 11:48 PM
