Old 07-30-2010, 06:37 AM   #1
1989 37' Airstream 370
Louisville , Kentucky
Door handle finally broke
After years of jerking and pulling on our door handle it broke this week. The key is marked tri-mark but I have had Little luck with them in the past. The latch is for an 89 and is not the same as earlier models I have seen posted. Any help would be great.
oliver00 is offline   Reply With Quote
Old 07-30-2010, 07:42 AM   #2
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
Hello, Oliver00 - A/S used to have replacements but they were the same old stuff - suggest looking for something outside the Airstream envelope. The door handle is not a difficult replacement, even with modifications to fit a non-OEM part. Good luck.
Jamie
jking is offline   Reply With Quote
Old 07-30-2010, 07:48 AM   #3
the ponz's Avatar
Detroit , Michigan
are you able to post a photo of the old handle?
86' 31' Sovereign
the ponz is offline   Reply With Quote
Old 07-30-2010, 08:47 AM   #4
The Bargmann L-300 works great as a replacement.
Old 07-30-2010, 12:06 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
What actually broke?
I have replaced the spring once and rewelded to latch once. But what broke on yours. Picture would be great.
2004 Excursion 4x4
door, door latch, handle, latch
I Broke the Greywater Dump Valve Handle 1Michigander Waste Systems, Tanks & Totes 10 06-26-2014 06:24 PM
Dump Valve Handle - broke... Craig Waste Systems, Tanks & Totes 11 01-22-2011 07:46 AM
door handle T&Cairstream Doors & Locks 2 12-11-2007 10:58 AM
