Old 11-28-2015, 08:50 PM   #1
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Doing the maths = disappointment
I'm a big fan for having a plan B, a spare, back up; from cars to motorbikes and everything but my wife, I have always felt better having a Plan B.
The Airstream has been no different. I allways have one good eye cocked on KIJIJI (our version of Craigslist) for anything remotely to do with Isuzu/Allison/Airstream/Keeler, you get the drift. I need a Plan B for the motor tranny in my 310, so you'll forgive the excitement I felt when I came across this ad.........
Isuzu 6HK1-TC ENGINE | parts, accessories | Hamilton | Kijiji
Pre 2007, so unencumbered with all the emission crap that post 2007 diesels have; motor has low use, less than 60,000 miles and for a reasonable price, especially if I could swing the Allison tranny with it. If the motor and transmission comes with the vehicle, all the better.
The problem is with the maths. The 6H1K-TC motor is 52.36" long, 34.66" wide and 43.5" high compared to the 6BD1 at 44.1" long, 25.5" wide and 30.5" tall. Now I don't know how much of these dimensions have the ancillary stuff tacked on that could be moved somewhere else, like the intercooler. Is the intercooler included in the engine length I wonder, or is the turbo right on top of the motor which would add to the height? Turbo's can be moved, not easily but it can be done.
I would love 300hp in my 310 but the oil changes would be deadly....33 litres.
I still think I might look at it.
Cheers
Tony
Old 11-28-2015, 10:07 PM   #2
1995 36' Classic 36
Ludington , Michigan
Looks awful big! You might be trying to stuff 50 lbs of taters in a 30lb sack! Look into a Cummins 6.7.
Kota is offline   Reply With Quote
Old 11-29-2015, 06:29 AM   #3
Tony, I wouldn't be surprised if the two engines are actually closer in length. Like you said the ancillary stuff could be the issue.
By all means go look at the truck and take some measurements. At a minimum you would be able to eliminate a certain type of engine but at the same time you may just find that it will fit
Old 11-29-2015, 06:52 AM   #4
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
It would probably cheaper to just buy one factory built, I am in the process of putting a 59AB flathead in a model A ford it is getting expensive and time consuming ,but I like doing it....
What a disappointment Roadtoaster Trailer Values 7 10-22-2007 08:38 PM
chat night a disappointment!!!! tslanier Our Community 34 11-10-2006 06:30 AM
Lansing Rally - 2004 - What a disappointment! 3237 WBCCI Rallies & Events 84 09-06-2004 09:11 PM
