Old 06-26-2009, 11:47 PM   #1
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
Doghouse upgrade
It's time to fix up the doghouse so that if anyone wants to see the engine, they won't see all the duct tape and worn out seal material falling off. What do you all use to fix up the motor side of the doghouse? Now that my '65 Corvette is almost ready to take racing, I'll be towing it with the MH. The hitch was upgraded to 5K lbs.
The underside has lost it's insulation. The edges have lost the foam seals. The floor area has lost it's seal also. Where can I get that stuff and are there any suggestions to make it look better than stock? Thanks.
1992 Airstream 300LE, rear queen, Banks Power!
Astrodokk is offline   Reply With Quote
Old 06-27-2009, 08:29 AM   #2
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Camping World sells a dog house insulation kit which includes foil covered sound deadener, foil tape, and spray adhesive.
I put off doing mine for a couple of years because I was afraid the new deadener wouldn't work as well as the old stuff. When I finally installed the kit, it was much quieter than the old stuff. My dog house has a rubber gasket on the edges and I didn't find a replacement.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 06-27-2009, 10:11 AM   #3
Astrodokk's Avatar
Thanks. I have a CW about an hour away, so I'll go there first. The rubber gasket is rotted out so I'm going to have to fabricate something myself. I'm sure I'll find something at Home Depot or local auto shops. Since the thoing pulls out, I suppose it's easy enough to work on.
Old 06-27-2009, 05:48 PM   #4
guy99's Avatar
Images: 16
I'd suggest you call Camping World and confirm that they still carry the product and it is in stock.
What I did was cut the sound deadening material to fit the dog house in a single piece with minimal seams first. I then set that aside and used the remainder of the material to apply a first layer with more seams, then I used the (relatively) seamless piece to form the outer layer. It came out pretty neat and does a good job with the sound.
Old 06-28-2009, 05:57 AM   #5
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
Hi - I have replaced the doghouse perimeter seal (side and rear edges where it meets the floor) with good results. Unfortunately I don't remember where I found the part, but the AS 800 parts number was helpful - I do remember that. Don't give up; there is a replacement seal out there somewhere.
Jamie
jking is offline   Reply With Quote
Old 06-28-2009, 03:05 PM   #6
Astrodokk's Avatar
jking,
Would you happen to have a photo of your restoration? If I can see what you did, I may be able to get an idea of how to fix mine. If not that's OK.
Old 06-29-2009, 06:20 AM   #7
Jamie
jking's Avatar
1984 31' Limited
Originally Posted by Astrodokk View Post
jking,
Sorry, my friend, that was several years ago and before I owned a digital camera. No photos available. On top of that we have now recovered the doghouse with carpet material to further reduce the noise (it helps!).
-Jamie
Old 08-15-2009, 10:15 PM   #8
guy99's Avatar
Images: 16
Astrodokk,
Just curious, did you find a doghouse rebuild kit at Camping World?
Old 08-16-2009, 06:28 AM   #9
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Millsupply.com The stepvan catalog.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 08-16-2009, 09:46 AM   #10
Astrodokk's Avatar
I haven't worked on it yet due to the heater core leak that I'm getting ready to fix. Also, I had a propane leak somewhere at the stove area and getting a plumber to fix that too. Before I can drive it to CW, it has to get charged up and driven for smog. But now that Glen has suggested that link, I may do it online! Thanks guys. I definitely will post the results after I'm finished with the doghouse. I have a priority of getting a floated valve fixed in my drag car, since the season is going strong right now.
Old 08-24-2009, 11:19 PM   #11
1982 28' Airstream 280
Elkmont , Alabama
I don't know but I bet there is some very modern insulation for that purpose. I'm going to do same with mine.
deltatango is offline   Reply With Quote
Old 08-25-2009, 06:29 AM   #12
GlenCoombe's Avatar
Belleview , Florida
Images: 27
I actually used rigid foil backed insulation that I cut and attached with a spray on adhesive. I finished it all up with foil tape on the seams.
It doesn't have to be pretty.
Mine has held up for 3 years and 60,000 miles.
Old 08-25-2009, 11:00 PM   #13
1989 34.5' Airstream 345
Silverton , Colorado
Doghouse of a different color...?
I use a sleeping bag, as I sometimes have to sleep in it...m
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 08-26-2009, 12:27 AM   #14
Astrodokk's Avatar
OK, the engine cover is off as well as the entertainment center console. I will take pictures tomorrow. It seems that someone has worked this before because the driver's side floor (5/8" plywood) is not cut right and encroaches upon the seal area. There's very little rust, so some fresh paint and new insulation will look great soon! BTW, I had to buy a new battery to start the engine for smogging, which passed. The old one was over 6 yrs. old and would not charge any longer. Hopefully the coach batteries last longer. I'm keeping the opening "open" for a while as I'm in the process of cleaning up the engine compartment too. The AC is coming out and I had a plastic fuel filter that was soft, so I replaced with a NAPA metal canister one. There's actually alot of room in there!
Airstream Doghouse Lee Pace The Pet Forum 14 02-22-2011 02:57 PM
Land Yacht doghouse gaskets Taxman Land Yacht/Legacy Motorhomes 4 02-07-2008 07:41 AM
My new "Doghouse" - 1970 31' Sovereign wivell Member Introductions 6 08-16-2006 08:00 AM
Doghouse designs? ALANSD General Motorhome Topics 14 02-09-2006 05:16 AM
First time owner, doghouse issues gsymes Our Community 6 01-20-2004 05:41 PM
