Old 02-05-2010, 09:27 AM   #1
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
Question Does the 81 Excella 280 have a parking brake on the drive line?
I was talking to the Gear Vendors guy at Chuck's Speed and RV (Phoenix) yesterday and he was very familiar with Airstream Classic Motorhomes but had never installed one on a 280 with the Isuzu diesel. The first question he asked me is if it had the parking brake (drum) down stream from the TH 400 on the drive line. I was stumped. I don't recall seeing this in my crawls under the coach. He needs to know to give me an accurate quote (got the impression if the answer was yes our price went up). I will go look today but I thought I would check with the AirForums brain trust first. So do we have this?
Ken
4CU Charter Member
silverback is offline   Reply With Quote
Old 02-05-2010, 09:30 AM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Mine does and they re-installed it when the U.S. Gear o.d. was installed.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 02-07-2010, 02:30 PM   #3
silverback's Avatar
2006 28' Safari SE
No. It doesn't.
Finally had an opportunity to crawl under the Excella this morning and down stream from the TH 400 is a short cross member, almost like a skid plate for the first U-joint and then the first drive shaft. No brake drum.
Ken
4CU Charter Member
Old 02-07-2010, 02:38 PM   #4
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I'm most curious what it has for a parking brake. Does it have drum brakes on the rear axle? If it has disc brakes aft I'm really curious?
Cheers, Dan
Smartstream is online now   Reply With Quote
Old 02-07-2010, 02:56 PM   #5
Mike Leary's Avatar
Images: 11
Cheers, Dan
Me too, that seems strange.
Old 02-07-2010, 03:47 PM   #6
silverback's Avatar
2006 28' Safari SE
Rear drums
It has rear drums on the dually wheels. From page 1-35 of the shop manual:
  • Never drive vehicle with parking brake set as this may overheat or otherwise damage rear brakes.
Nice to have the manual but I still had to go look.
Ken
4CU Charter Member
Old 02-07-2010, 04:03 PM   #7
Drum brakes answers the question. I wonder if all 81' and earlier have drum brakes or if discs were an option? Apparently 82' and later had disc front and rear.
Cheers, Dan
Old 02-07-2010, 04:13 PM   #8
Mike Leary's Avatar
Images: 11
Ah yes, Our '82 28 footer had four wheel disks; that must have been the turning point.
Old 02-07-2010, 04:19 PM   #9
Another thought, I have a 79' GMC 5000 with drums all around and a drive shaft parking brake. I guess the lads at GM did things somewhat randomly.
Cheers, Dan
New leak #2 81 Excella 280 TD silverback Classic Motorhomes 4 12-26-2009 10:11 PM
parking brake: suggestions? turfclubroad Brakes & Brake Controllers 6 07-05-2009 05:35 PM
Drive line vibrations bkahler Mechanics Corner - Engines, Transmission & More... 17 12-20-2007 05:34 AM
Should I get a parking brake on my new axle? FrenchBern Brakes & Brake Controllers 8 05-12-2007 04:33 AM
parking brake remcolent Brakes & Brake Controllers 5 03-24-2007 08:31 AM
