Old 03-30-2014, 04:13 PM   #1
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Disconnect the ice maker
Does anyone see a problem with disconnecting the waterline and fill valve and using just the refrigeration of the ice maker to store ice? Plug the waterline feed before the auto-fill valve and disconnect the positive side of electric?
mayco is online now   Reply With Quote
Old 03-30-2014, 05:22 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I disconnected mine because the cube maker mechanism didn't work. Don't usually put ice in my beer anyway. When I rebuilt my water system I put a valve behind the shower so that when I winterize I don't have to worry about water in the line to the ice maker. With the rear bath the water goes from the galley to the rear across the back and back forward to the ice maker. I'm not sure of the water routing on a center bath.
Cheers, Dan
~ Margaret Thatcher ~
Old 03-30-2014, 05:33 PM   #3
mayco's Avatar
Good idea to use a valve rather than a plug to winterize it.
Old 03-30-2014, 09:53 PM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I'm not putting mine back. I pulled it out and was very surprised at how much that 1'x1' cold space weighed. That unit weighs 60 or 70 lbs. I'm turning that space into a pullout garbage and recycle drawer.
I'm going to take the line through the floor and put a valve on it.
Old 03-31-2014, 08:32 AM   #5
mayco's Avatar
Stupidly, i was assuming the refrigeration was 110v and the valve selenoid was low (12v). So i just unplugged the connector from the valve and will operate as is for now. Still like the idea of an inline valve before the the selenoid for winterizing though. I THOUGHT i had learned years ago to never assume anything when dealing with electricity........apparently not.
Old 04-03-2014, 03:10 PM   #6
mayco's Avatar
Well, i was defeated. This cant be done according to the uline tech. Sooooooo, i had to reinstall the ice maker back into the little freezer. Has something to do with a cycling control located in the ice maker head unit. I thought it may be as simple as bypassing a switch but apparently its more that. The tech said it cant be done and i dont have the skills to challenge that........now if was made out of wood...id have a chance. So the head unit went back in and wires spliced back to original and the unit is working great and cycling properly. I just wish there was more room in there to store a larger container for bagged ice. I did however find a pesky small propane leak in the refrigerator shut off valve so the effort of pulling out the ice maker from the cabinet was not a total waste of time. I had no idea where that leak was but i would occasionally smell the propane. Now ive solved it.....ye haw
Old 04-04-2014, 03:55 AM   #7
1979 28' Airstream Excella 28
Commerce , Michigan
I replaced my ice maker with a kit from the appliance store 25 bucks works fine but just a little slower making cubes
Sent from my SPH-L900 using Airstream Forums mobile app
DA TAZ is offline   Reply With Quote
Old 04-04-2014, 05:25 AM   #8
mayco's Avatar
Good on ya there DA TAZ! I was trying to remove the ice maker head unit entirely and just use the little freezer for bagged ice. The reason for this is that my wife and i use bottled water for drinking and cooking. So i was trying to make more room in the little chest for "bagged" ice.
Old 04-04-2014, 07:40 PM   #9
woodja's Avatar
Dayton , Tennessee
Our ice maker generally makes more ice than we can use so after I empty it into the cooler I frequently put a clothes pin on the wire bail so it won't cycle but stays on & cold. You just have to remember to start it up again. Pete
woodja is offline   Reply With Quote
Old 04-04-2014, 09:03 PM   #10
mayco's Avatar
Woodja thats exactly what the tech at uline told me to do.
ice maker mlmarch General Motorhome Topics 13 06-29-2010 03:47 PM
fridge with or without ice maker remcolent Refrigerators 12 07-04-2008 10:18 AM
U-Line Ice maker in '94 LY blkmagikca Plumbing - Systems & Fixtures 5 08-15-2007 03:11 PM
Portable ice-maker experience? Kistler Our Community 6 06-22-2005 10:13 PM
Dometic with ice maker Minnie's Mate Refrigerators 0 09-27-2004 07:27 AM
