Old 08-16-2007, 09:09 PM   #15
1976 25' Caravanner
Campton , New Hampshire
The reason the timing can effect dieseling is because if out of spec too far it creates excessive heat . Anything that causes excessive heat or is glowing when the engine is shut down will ignite the fuel ( plugs,carbon,casting,valves,etc.) and result in dieseling, even without spark. I am not familar with an '86 454 in particular but some engines have an anti-dieseling device on the carburator to shut down the butterfly to prevent this . If so equiped , perhaps this device is not functioning properly.
ticki2 is offline   Reply With Quote
Old 08-19-2007, 12:14 PM   #16
jagcb750's Avatar
1986 30' Airstream 300
B , Louisiana
Update: I went to the gas station and put the highest octane gas in Ol' Nancy and have been shutting her down with it in drive or park and the "dieseling" has subsided for the moment. thanks for all the helpful comments. You guys are the best.
jagcb750 is offline   Reply With Quote
Old 11-25-2010, 11:27 AM   #17
1986 34.5' Airstream 345
Faribault , Minnesota
I found that heater on the electric choke was bad on Nancy causing the idle to stay "high" and not drop down to "curb Idle speed". Replaced choke and that cured the dieseling.
tswinsor is offline   Reply With Quote
