Old 07-29-2007, 12:07 PM   #1
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
Diesel woes
My 1984 310 turbo diesel (about 175000 miles) has developed a bad habit - on startup with cold engine there is a lot of smoke and it isn't all water vapor. Useful for fogging mosquitoes but not good for oil consumption. Smoking ceases when engine is good and warm, even on hard pulls. Anybody know much about valve guide leakage on these Isuzu things? Any other suggestions? Jamie
jking is offline   Reply With Quote
Old 07-29-2007, 12:16 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I don't have the answer, but if the mods could consolidate the three posts for this that are identical, maybe the responses won't be scattered.
Old 07-29-2007, 01:20 PM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Sounds like valve guide seals.
Michelle TAC MT-0
Sarah, Snowball
Old 07-29-2007, 08:25 PM   #4
1995 36' Classic 36
Ottawa , Ontario
Symptoms you describe are consistent with a turbocharger whose oil seal is failing. It will leak oil into the engine on shutdown and then leak some more until parts expand when it warms up. My old Mercedes diesel did this also and I ran it for several years. Aside from the oil consumption and environmental concerns, it may well run fine for some time in this condition.
John
shadejo is offline   Reply With Quote
Old 07-29-2007, 08:32 PM   #5
1976 25' Caravanner
Campton , New Hampshire
Is it actually using oil ? If not it may be diesel oil burning which could be the injectors leaking after shut-down .
ticki2 is offline   Reply With Quote
Old 07-29-2007, 11:01 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I will place my money and bets on "ticki2"
Hi, shadejo. Was that your Mecedes that sprayed the front on my car with black oil?
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-30-2007, 03:16 AM   #7
Jamie
jking's Avatar
1984 31' Limited
Yes, it is using oil. I had the injectors out and bench-tested just three months ago. The turbocharger seal an idea I hadn''t thought of yet - thanks. I hope it cuntinues to run for at leatds an other month, since we are currently in Newfoundland and have to get home. Then we'll investigate further. Thanks for your espertise. Jamie
Old 07-30-2007, 07:14 AM   #8
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
My 345 always does that on cool mornings and I am not using any oil at all. The engine is just to cold to properly burn the fuel and it will clear up as the engine warms up. On hot days it doesn't do it at all.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 07-31-2007, 01:55 PM   #9
1991 35' Airstream 350
Windsor , North Carolina
When you get back stateside, consider getting your oil analysed before you change it. No matter how you are burning oil--as opposed to leaking it out, or just blowing it out--an oil analysis may point you to the problem(s) and save you money in the long run. Costs about $20.00.
Best,
R
How's Newfoundland? Always wanted to go--
ralley is offline   Reply With Quote
Old 08-03-2007, 03:55 PM   #10
Jamie
jking's Avatar
1984 31' Limited
Well, I had a brainstorm - the 'crossover pipe' from turbocharger to intake manifold ought to be clean inside UNLESS the turbo oil seal is leaking. That would tell which problem I have. Test: remove the turbo boost gauge sensor nipple and stick in a long Q-tip. Result: oil! Now to find a place in southeast Newfoundland where turbochargers can be reliably repaired. BTW, This is a fabulous trip! You really really ought to plan on doing it soon!
Jamie
Old 08-03-2007, 05:06 PM   #11
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Good luck on that. My guess is that you will have to locate a rebuilt unit. Many years ago I rebuilt irrigation engines. One winter when business was slow I rebuilt about 25 turbos. The hardest part was getting parts. It took our parts guy over a month to find someone to sell up seals and bearings. Be sure and check that the oil return from the turbo to the engine is not clogged. I have see that cause oil to leak into the intake. It had coked up. Clearing that solved the problem without replacing the turbo. Worth checking.
By the way, good detective work!
Vaughan
Old 08-03-2007, 05:12 PM   #12
1983 34' Excella
1967 24' Tradewind
Images: 32
Oh, and if you do have to change it…Stainless Steel bolts and antisieze!
Vaughan
Old 08-07-2007, 10:20 AM   #13
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Your Isuzu is a mechanical engine-no computers here. You need to get the valves adjusted at regular intervals. I have mine done every other oil change or at 20,000 miles. It is a simple procedure and does not cost much.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 08-14-2007, 04:25 PM   #14
Jamie
jking's Avatar
1984 31' Limited
Well, it happened: the oil seal blew out and the thing threw oil all over the M/H, the road, and the car behind. Good news is there IS a place in Newfoundland that can rebuild an old out-of-production turbochgarger. Diesel Injection Service in St. Johns rates several gold stars in our collective book!!! They don't overcharge travelers/tourists, either!!
Jamie
Diesel tow vehicle-tips? maxandgeorgia Tow Vehicles 27 08-27-2006 10:28 PM
Water Heater Woes airstreamcaravel Water Heaters, Filters & Pumps 3 09-07-2005 09:18 PM
Isuzu Turbo Diesel stuart1 Mechanics Corner - Engines, Transmission & More... 0 10-28-2002 01:23 PM
Review Woes uwe Forum Admin, News and Member Account Info 7 09-20-2002 11:13 AM
Ford Diesel RV Puller 3 axle FrankR Tow Vehicles 0 05-03-2002 06:47 PM
