Old 08-14-2007, 04:37 PM   #15
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Glad to hear it, Jamie,
I have been wondering what was happening with your turbo. Make sure they clean the drain line from the turbo back to the sump. Let us know details when the repair is done.
Vaughan
Old 08-22-2007, 06:49 AM   #16
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
Smile Job Done!
Well, the thing is done! The turbocharger was removed and rebuilt in St. John's, Newfoundlland (Viking Diesel Service aka Diesel Injecton Service, should anyone ever have the need - they're OK). Cost about $2k. BIG IMPORTANT HINT: Check your turbocharger air intake hose (between air filter and turbo). Mine was torn open and let in road grime and dust, which led to the demise of the bearing. Noticing that last winter and replacing the hose would have saved $$$.
Jamie
jking is offline   Reply With Quote
Old 08-22-2007, 07:11 AM   #17
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Jamie
Im not sure what engine U have but what it sounded like to me is U dont let that engine cool before SHUT DOWN! this contributes to the seals goin out .A little egg timer on the dash will do it. 3 minute cool down beFore SHUTDOWN will cool the Turbo down enough for shutdown.
I have a 7.3 liter International Deisel in My f 350 Ford I use that techineque. Ihave driven Diesel engines for 40 yrs and never lost a turb0.
Exhaust temps can reach 1000 degress thus a HOT SHUT DOWN can distroy the seals in the turbo
Lot Of Luck to U
Roger
Mikethefixit is offline   Reply With Quote
Old 09-02-2007, 07:00 AM   #18
Jamie
jking's Avatar
1984 31' Limited
Roger -
Thanks for the tip. I have been doing exactly that for the past fifteen years, on two different turbocharged diesel motorhomes. This problem came up after a trip to the southwest (dusty) with the intake tube wasted, anmd the inside of the turbo looked sandblasted.
Jamie
Old 09-02-2007, 05:20 PM   #19
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by jking
Roger -
Jamie
Hi, at the Ford dealer, where I work, I have seen these sand blasted turbos; Caused by what I call "Mickey Mouse, Hong Kong, After market" air cleaners. For 5 more horse power, you get to buy a new turbo. Such a good deal.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-02-2007, 05:59 PM   #20
StingrayL82's Avatar
San Angelo , Texas
Images: 37
Could be worse...his cylinders could be dry-washed.
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 09-02-2007, 06:14 PM   #21
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Frederic
Yikes! Melted rings, galled pistons, scored cylinder walls, not a pretty picture...
Diesel tow vehicle-tips? maxandgeorgia Tow Vehicles 27 08-27-2006 10:28 PM
Water Heater Woes airstreamcaravel Water Heaters, Filters & Pumps 3 09-07-2005 09:18 PM
Isuzu Turbo Diesel stuart1 Mechanics Corner - Engines, Transmission & More... 0 10-28-2002 01:23 PM
Review Woes uwe Forum Admin, News and Member Account Info 7 09-20-2002 11:13 AM
Ford Diesel RV Puller 3 axle FrankR Tow Vehicles 0 05-03-2002 06:47 PM
