Old 10-08-2008, 03:08 AM   #1
doiliapeel , brabant
diesel engined motorhome under 3.5 tonnes
Hi all,
I was /am considering an Airstream Motorhome but being holland based and with a driving licence permittting only vehicles under 3.5 tonnes many vehicles are too large/heavy.Which if any of the older airstreams are diesel engined and qualify as above,was there ever any version built on a Mercedes chassis???.
I posted a similar query a long time ago but didn't ever get any reply.
Brian
brianhymer is offline   Reply With Quote
Old 10-08-2008, 07:07 AM   #2
Brian,
Our 1984 31' 310 Classic motorhome has a GVWR (gross vehicle weight rating) of about 14,000 lbs. Our 1974 20' Argosy motorhome has a GVWR of 10,500 lbs. I'm pretty sure the 20' Argosy has a typical curb weight of about 8,000 lbs so it would appear that even the smallest Airstream motorhome is going to be over your 3-1/2 tonne limit.
Now if you're referencing the metric tonne (2204 lbs) (3.5 x 2204 = 7714) then it appears that the 20' Argosy would come close but still would be a little over your limit.
I've never had the opportunity to weigh our 20' Argosy so can't say if it would fall within the 7714 lb limit. Also ours has a 454 gas engine and I believe a diesel engine would weigh several hundred lbs more.
To the best of my knowledge all of the older Airstream motorhomes were based on the Chevy P30 chassis. I believe the very last Classic style motorhomes that were made were diesel pushers based on a Ford or some other brand of chassis however these were in the 35' and longer category.
Hopefully someone will chime in with some better information for you.
Smokey 310 isuzu diesel motorhome WHY??? Illinois Mechanics Corner - Engines, Transmission & More... 3 04-13-2008 06:18 PM
1983 310 turbo diesel motorhome Illinois General Motorhome Topics 1 04-07-2007 06:36 PM
Water Pump in 1984 Isuzu Diesel Motorhome Snadi Mechanics Corner - Engines, Transmission & More... 4 02-08-2006 07:50 AM
1982 excella diesel airstream motorhome engine spec's jeniamundo Mechanics Corner - Engines, Transmission & More... 9 11-02-2004 08:24 AM
