Old 11-20-2014, 08:30 AM   #15
1995 36' Classic 36
Ludington , Michigan
Name:	ImageUploadedByAirstream Forums1416497271.334584.jpg
This procedure is really easy to perform and will cost you less than $10 at the local hardware store. It should be part of any prepurchase inspection on a Cummins.
Kota is offline   Reply With Quote
Old 11-20-2014, 05:06 PM   #16
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Picture of blowby tube location?
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 11-20-2014, 05:20 PM   #17
1995 36' Classic 36
Right below the fuel filter.
Old 01-06-2015, 10:27 AM   #18
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
A thread over on CF this subject of heaters. A silicon pad heater affixed to the side of the engine oil pan raises that fluid up 50F in three hours +\-
Pad on pan bottom may cook oil somewhat. I like the pan side location also.
With prewarmed coolant and oil, one is off to a better start. Literally.
Old 01-06-2015, 11:07 AM   #19
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Thank you slowmover. I havent ordered one yet. Do you have a link to CF? Is that Cummins Forum?
mayco is offline   Reply With Quote
Old 01-06-2015, 12:24 PM   #20
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Search. Too hot for fuel filter heater on CF
Old 01-06-2015, 08:33 PM   #21
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
My 1995 7.3L PowerStroke has a block heater that works very well. These days, I don't have to drive it to work, but the last 3 winters I did. I Plugged the truck in to a 110v outlet in my garage that has a timer on it. I had it set to come on a 3 am and shut off at 7 am. On cold mornings, it made the truck start nicely and helped get the HEAT going quicker, THAT's the real reason I plugged it in! Without the block heater, it would start (as long as the batteries were strong, the glow plugs were working well, and the glow plug relay was good.)
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 01-06-2015, 10:27 PM   #22
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
On a Cummins powered pickup if one runs the block heater he will get 90% of the total temp rise in 90 minutes.
Mine will bring the coolant to 115F but no higher.
Old 01-07-2015, 04:15 PM   #23
Bex
1976 Argosy 28
Eckville, Lacombe County , Alberta
Send a message via Skype™ to Bex
I think Paul and Gina hit the nail on the head. Glow plugs AND a block heater will give trouble free starts every time but one or other not performing as they should and you will go through batteries or, like me, a starter as well.
Bex is offline   Reply With Quote
Old 01-08-2015, 03:12 AM   #24
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Upgrading power cables and terminals is another good step.
As to going through batteries I got nine years from the OEM set and that was quite common for other Cummins pickup owners. The recommended upgrade is rebranded Odyssey Sears Diehard Platinum.
Broken Fuse Block In Distribution Panel - How Best To Repair montanaandy Batteries, Univolts, Converters & Inverters 12 06-01-2015 08:01 PM
Older 3/4 ton suburbans - engine history diesel/big block Jammer Tow Vehicles 10 02-25-2010 07:10 PM
block heater apetit Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 2 01-20-2005 07:01 PM
Value of Conductive stabilizer block aluminauts Our Community 4 02-20-2004 05:03 AM
Leveling block templates ctdair Jacks, Stabilizers, Lifting and Leveling 1 11-14-2003 11:34 AM
