Old 03-25-2017, 09:56 PM   #41
Moodified13's Avatar
1984 31' Airstream310
Bossier City , Louisiana
Install completed! It performed perfectly, 2400 rpm at 70mph, 190 degrees, trans at 100 degrees, ac works great, transmission shifts smoothly and downshifts properly. No leaks anywhere. It has tons of power, is 3 times as quiet as it was (almost as quiet as my 2007 f-150), and if I felt like it would easily do well over 100mph. I took it to 80 just to see how it would do and easily had at least another 50% pedal. At 70 it feels like it is hardly working. Overall I'm extatic, everything I wanted to accomplish with this swap was met and exceeded.
I drove it on the maiden run 100 miles to Texas. It got 9 mpg in some pretty good hills. I'm ecstatic with this. The 454 got 5 or 6 on a good day. I was able to talk on the phone and listen to the radio at a reasonable volume. It definitely doesn't lack for power and I have to be careful not to get it going too fast. I really enjoyed the drive. I'm pretty sure that if this power plant was available in 84 Airstream would have put this combo in them instead of the 454/475 combo. I am curious to see what it will get on the interstate without all the hills. I'm hoping for 10, but will not be disappointed if it does no better than 9.
Cruise worked great. Definitely didn't have to babysit it in the hills like the old vacumn system! The added torque is definitely noticeable on cruise. It never checks up and easily pulls hills on cruise with no driver input. Only the steepest hills make it want to downshift!
Moodified13 is offline   Reply With Quote
Old 03-26-2017, 05:36 AM   #42
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I have a turbo diesel so have no need for the swap but I'm sure a bunch of people here are looking at this thread and drooling, so I'm going to ask the all important question.
Excluding the donor vehicle which would be a variable, how much in total did this swap cost you in parts and labour? When I talking labour I'm talking man hours.
Knowing what steps you could save time, taking out the R&D time, troubleshooting etc, etc; how much labour would it take for you to do the next swap?
If a forum member was interested and supplied the donor OR you could supply the donor, would you be interested in possibly doing this very same conversion? If so, how much would you charge for the conversion?
Seriously, there are guys here that would seriously think about this.
While this may not be your profession, the manner in which you have accomplished this task is bloody professional in my book. I'd be the first to state that I'd trust your workmanship.
You have accomplished in three pages what other "professional shops" would have screwed up in 10 pages.
Cheers
Tony
Old 03-26-2017, 06:45 AM   #43
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
What he said!
mayco is offline   Reply With Quote
Old 03-26-2017, 07:16 AM   #44
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Very impressive!
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is online now   Reply With Quote
Old 03-26-2017, 07:46 AM   #45
Dazed and Confused
Isuzusweet's Avatar
Just in case any of you gasser boys are tempted........87,812 miles on the truck.
With the exchange rate the way it is...$3900.00 USD if you couldn't talk him down.
http://www.kijiji.ca/v-cars-trucks/m...ationFlag=true
Take your coach to Loiusianna, while they do the take out and getting of parts together, fly up to Calgary and take in the Calgary Stampede and then a nice drive down to Louisianna with the pick up for the swap. Lance, you up for this with your 345?
Cheers
Tony
Old 03-26-2017, 11:20 AM   #46
1986 34.5' Airstream 345
Alliance , Ohio
Tempting, very tempting.
mehes is offline   Reply With Quote
Old 03-26-2017, 12:04 PM   #47
Dazed and Confused
Isuzusweet's Avatar
See what you've start Moodified13, customers are already lining up......and you thought I was kidding!
Maybe if you're unwilling to offer your services in Louisianna, offer a parts list and a kit, like plans for the forklift motor extraction pieces, complete wiring harness, instructions, tips, bandaids and Viagara.
Cheers
Tony
Old 03-26-2017, 08:53 PM   #48
My buddy Trey and I have done 8 or so LS swaps (modern Chevrolet motors. 5.3, 6.0, 6.2 etc.). We are both gearheads and like building as much as driving. We did this one in 7 weeks from start to finish. With full time jobs, that is a lot of late nights! I will be glad to help anyone interested in doing this. I'll be glad to provide part numbers, vendors, or advice! We do occasionally take on work outside of our own projects, but it's not something we are actively pursuing.
This particular swap cost me around $10,000.00 before selling the donor and the old 454 and transmission. If you have never done a swap the little stuff adds up quick. Machine shop work, custom hoses, new radiator, new radiator hoses, electric fans, fluids, Abbott cable-x (speedometer converter).
I'd have to talk to my building partner on what we would do another one for, but I figure we have 600-700 man hours in this swap. Labor would be the most expensive part of the quote.
ID:	282167   Click image for larger version
ID:	282169   Click image for larger version
Old 03-30-2017, 08:41 AM   #49
Finished product
Took the airstream on another 100 mile run, I was following a buddy and set the cruise on 72. It got 7.7 mpg. I could never have dreamed to travel at that speed and get that kind of mileage before. The drivetrain has yet to hiccup and it's nice not to have to babysit the carburetor on startup. I have a ton more confidence in it than I did my oily 454. Also nice not to have to put a pan under it to catch the oil leaking out of the old engine.
Old 03-31-2017, 07:28 PM   #50
mayco's Avatar
Beautiful
Old 04-01-2017, 06:21 AM   #51
Dazed and Confused
Isuzusweet's Avatar
[QUOTE=Moodified13;1929492]
Lance just loaded this photo on a computer key , drove to to the local Wallmart, blew it up poster size and has it laid out over his 454 under the doghouse. Now he just has to convince the boss.
Tony
Old 04-02-2017, 05:41 AM   #52
Alliance , Ohio
How about a glass doghouse?
Old 04-06-2017, 07:56 PM   #53
That would actually be a good idea. I've pulled it off at least a dozen times showing it off!
Old 04-08-2017, 07:36 AM   #54
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
Originally Posted by Moodified13 View Post
I already had a gauge. The 475 ran cool! Hope the Allison will too!
As I'm doing my own T-1000/cummins swap I learned I have too much transmission cooler and needed a thermostat bypass. The Allison don't work right below 141 degrees.
choctawmel is offline   Reply With Quote
Old 04-08-2017, 08:14 AM   #55
Silver Bullet
choctawmel's Avatar
choctaw , Oklahoma
After reading the whole thread, I'm kind-a feeling bad now: You did this in 7 weeks. My cummins/6-speed swap is going on 16 months!
But then I wasted too much time trying to get the 4L80e to work with the diesel before pulling the trigger on the Allison.
Old 04-09-2017, 07:10 AM   #56
Don't feel bad! That is the fastest we have ever done one! It was a lot of late nights with 2 of us, sometimes three. We also have a lot of experience with swapping LS based motors so that definitely speeds things up! Something that keeps my projects going is I try to get something accomplished every day even if it's small. Also, we keep a punch list on a marker board that we mark off and add to as unforeseen items pop up. Lastly, I try to stay ahead of the parts we are going to need so I have them on hand when needed. Nothing will slow you down more than waiting on parts to arrive!
Old 08-08-2017, 07:07 PM   #57
Alliance , Ohio
Any updates on this swap? Performance? Lessons learned? It really looks great. I'm still considering just such a project as I am sure many others are as well. It would be great to hear more.
Old 10-08-2018, 07:58 AM   #58
Update
I’ve put approximately, 8,000 miles on the 8.1/Allison since install. It has been absolutely flawless. I love how quiet it is and how cool it runs. One of my biggest concerns was keeping the engine and trans cool. The engine runs at 200 and the trans at 160. I love that I can now drive at a comfortable pace instead of holding traffic behind me for 6 miles. At 75 the engine is turning 2,500 rpm’s. Besides a couple of oil cooler lines that required tightening and an alternator that had to be replaced, it has required no other maintenance.
Old 10-08-2018, 08:50 AM   #59
Magnet18's Avatar
Churubusco , Indiana
I just found this thread, and wow, well done!
That engine looks beautiful in there!
Previous owner of mine went with a rebuilt carbeurated 454 and Gear vendors. I get similar MPG/RPMs, but like you said, it's an expensive accessory behind a 40 year old drivetrain, and they're known to be prone to issues.
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 10-08-2018, 11:56 AM   #60
DreamStreamr's Avatar
2005 25' International CCD
Fleetwood , North Carolina
Images: 38
Send a message via Skype™ to DreamStreamr
My 2006 8.1L/Allison has been flawless for 226,000 miles, 150,00 of those towing an RV all over North America. Gas mpg and oil consumption aren’t great but reliability and smoothness worth it.
Great thread, pictures, writing. Enjoyed reading about your swap.
Chasing 75 Degrees,
Jim N5RTG
dreamstreamr.com
DreamStreamr is offline   Reply With Quote
Motor swap '82 310 chiefair Classic Motorhomes 134 09-03-2023 12:52 PM
2011 Airstream Avenue One Owner Class B Motorhome Only 3K Miles 6.0L Vortec eBay Watch Airstreams on eBay 0 11-29-2013 02:50 PM
2011 Airstream Avenue One Owner Class B Motorhome Only 3K Miles 6.0L Vortec eBay Watch Airstreams on eBay 0 11-23-2013 06:20 PM
1984 Airstream 310 Motorhome Chevrolet 454 Runs and Drives great, needs TLC eBay Watch Airstreams on eBay 0 01-23-2012 05:40 PM
Mid 90's Vortec 454 transplanted into a vintage wagon? 72Blazerod Tow Vehicles 14 02-08-2009 05:58 PM
