Old 07-22-2005, 07:52 PM   #1
jaiman's Avatar
Images: 32
Deep cycle battery switch
I only got about a year and a half out of my deep cycle batteries. (2) According to the guy at Napa one of the possible reasons they both died is that there might be a slow continuous drain on them. He suggested I install a disconnect switch. Makes sense to me. Questions: Which side pos or neg? He thought the possitive side but wasnt really sure. Has anyone else done this. I found a great spot in the belly storage locker right in front of the steps. There is a box riveted there to protect the positive cables that run through it. Any thoughts or pics from any one would be greatly appreciated.
Jai
jaiman is offline   Reply With Quote
Old 07-22-2005, 08:26 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
cut off switch
"They" say negitive side but I cut the positive.
This is a less expensive version of cutoff switches and works fine. I think its good for 100 amps. Key can be removed I have a tie on it to keep from loosing it.
I think the best source for cut off switches is any marine store if there is one near you.
Garry
Old 07-22-2005, 08:31 PM   #3
jaiman's Avatar
Images: 32
I just removed the protective cover for the cables in the trunk and find there is some sort of solenoid looking device that all the power is connected to. I assume this is the starter assist solenoid. I figure I can remove the deep cycle cable and attach it to one of the poles then take another new cable and attach it to the solenoid. This should enable me to mount the switch to the cover.
Old 07-23-2005, 01:28 PM   #4
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
I was told to keep the batteries fully charged and then they will not be subject to premature failure. We use our Chummy every week during the summer and almost that often in the winter. I do have a trickle charger for marine batteries that I put on when we are not leaving for over a week.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
New battery selector switch FrankR Electrical - Systems, Generators, Batteries & Solar 6 02-08-2013 06:34 PM
deep cycle battery replacement 26Argosy.ca Electrical - Systems, Generators, Batteries & Solar 6 01-02-2003 05:19 AM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Auto Battery problems.... kzener40 Airstream Motorhome Forums 10 08-05-2002 06:37 PM
