Old 04-16-2019, 04:11 PM   #1
Undereducated AS Newbie
1989 34.5' Airstream 345
Charlotte , North Carolina
Deadbolt Lock
I've had to crawl in the driver window multiple times due to the door lock not working with the key. It's becoming an irritation. Everything seems to work as it should with the panel off, while I observe the mechanism's movement.
Has anyone considered adding a deadbolt lock to the entrance door? It appears there's enough room to add the lock just below & to the left of the existing mechanism. My Revcon has a Kwikset Deadbolt.
I realize there will probably be a need to have a ring for additional support on the inside of the door for the outer portion of the deadbolt lock. Is there anything that would prevent the striker going thru the door frame or jamb?
wimpy is offline   Reply With Quote
Old 04-16-2019, 05:29 PM   #2
1972 23' Safari
Middletown , Rhode Island
I added a deadbolt to my 72 safari. It works great. Had my buddy weld a longer piece of rod onto a Home Depot deadbolt lock. Measured 10x and cut/drilled once.
Mx468 is offline   Reply With Quote
Old 04-16-2019, 06:19 PM   #3
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
https://www.vintagetrailersupply.com...-p/vts-343.htm
Works great. I don't use the door lock any more.
youngpeck is offline   Reply With Quote
Old 04-16-2019, 06:53 PM   #4
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Our 310 came to us with a deadbolt, itís the only lock we use.
Waipio Rim is offline   Reply With Quote
Old 04-18-2019, 08:40 AM   #5
1972 25' Tradewind
1976 31' Excella 500
Denver , Colorado
There are about a thousand threads on this forum about deadbolts.
Depending upon which handleset you currently have, some have issues with locking as a result of road vibration. In other words, they can lock just driving down the road, and depending upon their age, once they lock, the key often doesn't do much good to get them unlocked.
I almost always modify the handleset so that the lock no longer functions (it is only a latch), and then I add a deadbolt.
25' 1972 Airstream Trade Wind Land Yacht
2006 Jeep Liberty CRD (diesel)
http://BeahmStream.com
kidjedi is offline   Reply With Quote
Deadbolt Lock - will not lock due to pin strike point PSU1981 Doors & Locks 13 08-28-2018 04:22 AM
Help - Deadbolt Lock won't lock PSU1981 Windows, Doors, Locks & Vents 1 11-21-2016 12:04 PM
Installing a new deadbolt lock Moonshot Doors & Locks 7 10-08-2007 03:44 PM
deadbolt lock John Greenlee Windows & Screens 2 07-10-2004 09:33 AM
deadbolt with inside twist style lock CindyH Doors & Locks 4 10-16-2002 08:58 PM
