Old 11-04-2012, 04:23 PM   #1
huberto's Avatar
1979 24' Airstream Excella 24
Monterey , California
Dashboard switches '79 Airstream
Can't ID these green switches. (Except map switch, which works! Red step and door lights work fine too)
This is a 1979 Excella 24' with quite a few DC wiring issues. Another is no horn. Pulled the 15 amp fuse which was blown but horn does not work even after replacement.
Any help, much appreciated.
huberto is offline   Reply With Quote
Old 11-04-2012, 05:32 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
The trunk switch should be the outside storage compartments. The walkway switch should be the small lights that are just above the floor along the center aisle like night lights. The aux. is probably an extra for a custom application.
Good luck, Dan
Old 11-04-2012, 07:17 PM   #3
1974 Argosy 20
Kooskia , Idaho
They all work from the engine battery (at least those on my 310 did) so if you leave them on by accident, you can flatten the battery and have a no start situation. The green indicator lights help, but it is very easy to leave a switch on and not see the light.
Old 11-05-2012, 10:01 AM   #4
I concur with what has been said.
Maybe the AUX is the Aux heater fan switch... which on later models is under the drivers side couch and uses engine coolant to heat the living area.
Mine looked like this in situ.
Like this out and refurbished.
Your horn issue.
FYI, on the chevy chassis, that horn fuse also supplies power to the 12v cigar lighter recepticles.
If the fuse did not blow when you replaced it, then whatever caused it to blow, is either fixed or maybe intermittent...
At the risk of sounding like a salesman... I suggest you spend a little cash, and buy a Powerprobe 3... and if you can swing it, a Powerprobe ECT2000..
Best electrical diagnostic tools i have ever seen and used, and essential as a wrench for your issues!
With the PP3, you can just walk around the MH(30' cable), and at the push of your thump supply power or ground to a componant or switch, or read if something has power or ground, or is shorted.
The ECT2000 allows you to trace wires, both open circuits and shorts.
As a testimonial, a combination of these two tools allowed me to find the dead short on my Horn circuit which turned out to be this wire on the drivers side 12v recepticle that was punctured with a trim screw!
Old 11-05-2012, 02:06 PM   #5
huberto's Avatar
Thanks. I think I will invest in these tools. (Or else I am up the creek without a paddle.)
Old 11-05-2012, 02:33 PM   #6
I am electrically illiterate... I would never have found that short without them.
I put them on my christmas gift list and santa obliged....
In this case, I think "santa" was fishing for a trip to Yellowstone in 2013/14, and knew things needed to be up and running...
The PP3 and ECT2000 are about $100 each on Ebay, and just over $200 buys you both in a single box kit.
