Old 03-01-2006, 07:51 PM   #1
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Dashboard Makeover
I did it. Tore out my entire dashboard, gauges and all. I now have nothing but a mass of wires and loose hanging bulbs. What I really would have referred to do was plan this job before I got into it but that did not happen. I will be using the same wiring harness when I hook things back up thus the same gauges and same placement of gauges. It would have been nice to move things around but the wires were not long enough and I was afraid to try rewiring. New gauges were too costly at this time so the old will do. What I will have is an all oak dash cluster, newly padded, painted, and covered dash.
Attached are pictures of the oak cluster I just completed cutting and putting in the holes, now it will get many coats of poly.
Question when I reinstall the speedometer can I just insert the shaft back into the gauge or is there a special way to do this? Is there anything else I need to be watching for when I try to get this back together? I did label everything.
I never found a switch for the blower so purchased a face plate from a 2000 Suburban, erased the AC stuff, and painted the back. It will work fine.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 03-01-2006, 07:53 PM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Looking GREAT, Your some motivated this winter!
Can't wait to see the back together pics
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-01-2006, 07:58 PM   #3
Robfike's Avatar
1999 36' Land Yacht Widebody
Spencer , Indiana
Speedometer
You should be able to just push the cable back into the back of the Speedometer. You may find that the first time you drive it, you get a clicking sound and the spedo does not work. This happened to me. All I had to do was reach under the dash, pull the cable back out and reinsert it as I was rolling. It found it's own happy spot.
Great looking dash!
Rob
Robfike is offline   Reply With Quote
Old 03-01-2006, 09:24 PM   #4
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
I'd want to check the condition and size of all ground wires as you reinstall the guages. Lot's of issues with guage function and accuracy due to poor grounds. This is a major issue with my coach and one that I'm not looking forward to getting into...anytime soon. But on the horizon for me is a major look at the issue.
Looks like a great job of woodworking. Hope you labled all those connections before taking it all apart .
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 03-02-2006, 06:30 AM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
lookin' good so far....you might keep some templates of those pieces in case someone else does that job, they'd sure be happy to get them.
Looking forward to seeing this in person here in GA!!
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 03-02-2006, 07:46 AM   #6
1994 30' Excella
I used the metal front on the original dash as a template. After removing all of the gauges and lights (does anyknow what all those lights were for?) this came off of the vinyl back. Next I cut them into three pieces so they would be flat. Today I will cut out the labels such as Airstream, lights, wipers, etc. Thank goodness for a Mr. Dremel.
Chaplain Kent
Old 03-02-2006, 08:38 AM   #7
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
It's a good thing you are a Chaplain. I would need a lot of forgiveness if I was to take that dash job on. You must be a very patient man.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 03-02-2006, 09:42 AM   #8
1977 28' argosy moho
scarborough , ontario
Looks like you've got a handle on remaking your dash! I wish I had as much initiative. I can't wait to see the finished product.
Warbs is offline   Reply With Quote
Old 03-02-2006, 09:59 AM   #9
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Originally Posted by Chaplain Kent
. (does anyknow what all those lights were for?)
do you mean the light switches? If so mine are switched to turn on the floor lighting, the luggage compartment lights, and so on. I also wired one to my radio as a cut off, and to my front overhead fans.
AIR #005
retired!
Old 03-02-2006, 04:18 PM   #10
1994 30' Excella
There are five lights below the speedometer and tachometer plus two more right above the steering wheel. these lights are green and red. My manual does not identify them. Only three of of the five were wired, the two above the steering wheel were not wired. these are 12V lights.
Another question now that everything is apart. Any ideas how I could wire my headlights into the ignition switch so they go off when the switch is turned off? With the diesel the ignition switch is basically an on switch and I have a cut off switch elsewhere on the dash.
Chaplain Kent
Old 03-02-2006, 05:40 PM   #11
1991 35' Airstream 350
Windsor , North Carolina
Actually, you anticipate my question. When my 350 came back from its manditory state inspection, its headlights, when on, caused the headlight warning buzzer to sound, whether the key switch was on or not. It's damnably agrivating. Can you tell how the headlight circuit is wired to the switch? The warning buzzer is usually a small metal box which plugs into a circuit board behind the dash. The warning buzzer should only work if you leave the lights on and turn the key off......... It would be nice to know that what is behind my dash is ok, so I can look elsewhere for a bad ground, crossed wire, etc. They did replace a headlight during the inspection, but I find it hard to believe that you can screw that up!!
Sorry to intrude on your project with this--nice looking oak, that is. Make sure you clean all the grounds and replace any suspect wires as things go back together. Looks lovely!!
I checked my manual for the 345/350. It shows no dash lights below the spedo or tach--all are above, so either the 310 is significantly different, or only yours is!!
Rob Alley
ralley is offline   Reply With Quote
Old 03-02-2006, 05:48 PM   #12
1994 30' Excella
My coach never had a buzzer but i would sure like to have one. If you noticed in my post above the diesels are wired different from the ignition. I would also like a more secure ignition switch but the GMC guys said it does not exist.
Chaplain Kent
Old 03-03-2006, 08:29 AM   #13
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Thoes lights in mine are for a door alert when it is not latched, an alert when the hand brake is on, and I am not sure what else but will check it for you next chance I get.
AIR #005
retired!
Old 03-03-2006, 02:46 PM   #14
1994 30' Excella
I have got the gauge assembly back together. Next step will be cleaning up the wiring before installing it. I eliminated the lights under the speedometer since I really could not figure out what they were for.
ID:	18970   Click image for larger version
Chaplain Kent
To Paint or Not to Paint My Dashboard Chaplain Kent General Interior Topics 8 02-23-2006 08:41 AM
Makeover Update On '79 M/h RealShinyOne General Motorhome Topics 0 11-30-2005 06:55 PM
Television Makeover on my Argosy streamlean Argosy Motorhomes 15 09-03-2004 10:39 AM
Restore vs. Makeover andreaszabo Our Community 8 07-10-2002 06:57 AM
