Old 11-17-2011, 03:41 PM   #15
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
I have the dash apart, But I have more job to do. #1 make a table, #2 new door for my gen. #3 new rubber around my windows , thin by dash, ( just getting things in line for the dash
alfalsetto is offline   Reply With Quote
Old 11-17-2011, 05:18 PM   #16
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
The wiring under the dash on our coaches is, to say the least, atrocious. I'm very carefull when pulling the dash for fear of doing more damage. Most of my gauges have been replaced with Isspro, but the grounding problem is a factory screw-up.
ISSPRO.com Your home for quality Gauges, Tachometers, Speedometers, and more!
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 11-17-2011, 08:49 PM   #17
alfalsetto's Avatar
I see your going with the best gauges. All the gauges I put in trucks & bus in 50 years thay have been the beat!!
Old 11-17-2011, 11:24 PM   #18
Maniacal Engineer
barts's Avatar
Menlo Park , California
Originally Posted by dadstoy View Post
Hi Bart,
Do you remember which model of Auto Meter you used? Also do you know what is stepper motor gauges?
Dean
Auto Meter (AutoMeter) Gauges from egauges.com
I used the GS series since they matched the truck's gage colors..
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 11-18-2011, 09:18 AM   #19
1988 32.5' Airstream 325
calgary , alberta
Good Morning , snow and -16 c so cold and windy, time to get some projects done! How do you fix the ground problem of the dash? Run another ground and where to attach it? Also would this cause wipers to Quit? Thanks Jonathan
jhenry is offline   Reply With Quote
Old 11-18-2011, 11:32 PM   #20
Maniacal Engineer
barts's Avatar
I've not worked on an Airstream dash, but... the ground connection is going to come from the cases of the light bulbs... typical color is green, but someone may have gotten creative.
Get a DVM and go exploring. A wiring schematic will help a lot; being methodical and deductive will make sorting this out straightforward if a little tedious.
- Bart
Bart Smaalders
Menlo Park, CA
Replacement issues wander'n Refrigerators 0 10-11-2011 06:25 PM
Land Yacht Dash Air DonaldW Land Yacht/Legacy Motorhomes 25 07-21-2011 07:48 PM
Replacement Fabric nynick52 Awnings 10 07-21-2011 06:01 PM
Dash exchange shepherd57 Argosy Motorhomes 3 07-18-2011 03:20 PM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
