Old 08-06-2011, 02:33 PM   #1
AirRowan's Avatar
1986 34.5' Airstream 345
Key West , Florida
Dark Green wire headlight harnes?
There is a wire that has me stumped if any one knows would love help.
It is not a turn sig. That is all i know.
ID:	136895   Click image for larger version
ID:	136897   Click image for larger version
AirRowan is offline   Reply With Quote
Old 08-06-2011, 02:54 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I assume it goes tot he connector you are holding in the first picture. If so want are some of the other wires in that connector. Factories generally group similar systems in a connector. Again I assume you have tested it for battery voltage.
Take an OHM meter and ohm it to ground. That will at least tell you if it has a load on the other end. If it is open is there a trailer hitch connection at the rear of the MH?
2004 Excursion 4x4
Old 08-06-2011, 10:05 PM   #3
AirRowan's Avatar
Key West , Florida
The wire is part of the head light wiring harness and the trailer harness is part of the tail light harness. I check it and it pulls no load when hooked up to +power (dc). There is a relay in the loop so I think it may be some kind of flasher but not for the front turn sig or the rear......
I am stuck I hope Andy from inland RV can help. Or some one that has had the inner skin off one of these and seen were that Green wire go's.
Old 08-07-2011, 08:07 AM   #4
HowieE's Avatar
Images: 12
Consider hooking a length of wire to it at the cab end and taking that wire, out the window, to the trailer hitch and OHMing out each terminal in the trailer hitch for continuity. If you find continuity the position of that terminal in the trailer connector will tell you what the wire is for.
Disconnect the ground post on the battery before testing to protect your meter.
2004 Excursion 4x4
Old 08-07-2011, 11:01 AM   #5
The Airstream service handbook lists that a Green wire running off the lighting harness feeds the Aisle lights...... That might explain why no feed... unless the Dash switch is on?
Fingers crossed!
Oh, and also the Chev Manual says a green wire feeds LH Brake Lamp, and blinker.
My guess would be based on how it looks, its an Airstream wire, not a Chevy Chassis wire...
EDIT:.... I got that from the 1987 Airstream service manual.... Section G16... also it shows the Deadbolt feed as having a Green wire!
I can send you a copy if you dont have it... PM me your Email address.
Old 08-07-2011, 11:13 AM   #6
I recently saw a great Electrical tool in action...
Called the Powerprobe 3, and its on my wish list...
PP319FTC Power Probe III ....?Powers up Components!?
Might be worth the $100...
Old 08-07-2011, 11:51 AM   #7
AirRowan's Avatar
Key West , Florida
I figured it out the Horn......
ID:	136970   Click image for larger version
Old 08-07-2011, 04:31 PM   #8
1969 31' Sovereign
O , Central,Florida.
A power probe is the best circuit tester ever it will pay for itself 1st time used.
if you don;y have one make a jumper wire & put a ATC fuse in line & make it hot & see what lights / powers up if nothing then you case everything else until you locate the circuit.
SR66
Slowride66 is offline   Reply With Quote
Old 08-08-2011, 12:00 PM   #9
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
yes, Horn wire is correct.
John H. is offline   Reply With Quote
1988 Running Light Exposed Wire vhariable Lights - Interior & Exterior 2 06-25-2011 08:56 PM
Where does this heavy black wire go? malconium Electrical - Systems, Generators, Batteries & Solar 3 05-31-2011 01:07 PM
One Wire Running Lights---Effects on Grounding tinbender Lights - Interior & Exterior 7 04-18-2011 07:22 AM
Burnt wire on my univolt MonaxLisa Batteries, Univolts, Converters & Inverters 11 03-23-2011 12:31 PM
Running Lights LED - How do I route the wire? AirHome Lights - Interior & Exterior 6 02-20-2011 07:15 PM
